rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i'm stumped. at idle, i get a pulsing of fuel out of both of the accelerator pump jets on the pass side carb. they do not not leak with the engine off, with the key in the first position and the fuel pump engaged. driver's side does not exibit this. it occurs whether the linkage is hooked up or not, and the engine is idling. valves adjusted. i've been thru the setup proceedure repeatedly. side to side carb flow is balanced.
give me some ideas. the actuating arm is not bound on the cam and moves freely. so...incorrect float adj? stuck diaphram or one of the check balls missing or stuck? looking at the cutaway diagram on p58 of the cb book shows a good view of the circuit. there can only be so many issues. i contacted the outfit that rebuild my carbs. their diagnosis was tight intake valves and the back pressure upon compression was forcing the fuel out. that didn't make any sense to me. k |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Here is another possibility....
There is a check ball built into a screw UNDER your accelerator pump squirter. OR you have the early version which is a free check ball under a little brass rod. Either way. Yours is probably corroded or dirty or simply hosed. NOTE: Mark Harney has some REALLY good articles on rebuilding the weber carb.. Ya might want to peruse them and see if you can glean any new data for your carbs. Mharney Weber Pages Cheers, Clayton |
Lo-Fi Version | Time is now: 3rd July 2025 - 08:32 PM |
