Fuse keeps blowing~ |
mikeyboy_85 |
Oct 28 2007, 08:53 PM
Member Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
Today i got in to take my 914 out on a nice sunny day and i noticed that my guages were not working right, so i looked at the fuses and replaced the blown fuse, the when i put myfoot on the brake pedal the fuse blew again. i looked at all the wiring on the tail lights and all seems to be in good order, and all the globes are fine, where else should i look ??
cheers michael |
Spoke |
Oct 29 2007, 07:01 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Some ideas:
1) If you've worked on some part of the car recently, see if there were any wires moved that may be shorting. Check the wires in that area for shorting. 2) If applying the brakes blows the fuse, check the taillight wires for proper connections. That is, connectors securely attached and not touching each other and wire insulation that is not cracked or stripped back too far. 3) Question: does the fuse blow when the running lights or headlights are on? 4) Check the wires around the brake light switch on the pedal cluster. Look for frayed wire insulation or loose connectors. Spoke |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:35 PM |
