Weltmiester Rear Sway Bar Pictures or, Factory mounting pictures - I'd like to see some |
tracks914 |
Oct 27 2007, 04:45 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I'm looking for the installation instructions or good pictures of a properly installed Weltmiester rear sway bar.
Anyone??? thanks |
Chris Pincetich |
Oct 29 2007, 04:56 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Doug - I sent some pics to you via email. Unfortunately, I don't have a pic of how the length of the bar tucks up under the muffler, tough angle to photo. Also, I have read that the bar can be mounted either way, with lower cars benefiting from the bar mounted "upside-down" so the ends bend down instead of up (?). If your car rides really low, and the drop links are long, they can bump the trunk at full compression. Chris Foley once posted some pics of his micro drop links, and some 914 GTs had the rear bar mounted IN the trunk with drop links through holes drilled in the trunk. Now that's a little extreme... (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 06:46 AM |
