| xperu |
Nov 1 2007, 01:30 PM
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None
I have the transmission out of my 73 while the engine is being rebuilt. Can you guys give me some advice on what I should inspect for and replace. The transmission was working fine when removed about 2 months ago with no leaks, grinding, noise etc. I not sure of it's previous history. Thanks Mike
| dr914@autoatlanta.com |
Nov 1 2007, 02:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I have the transmission out of my 73 while the engine is being rebuilt. Can you guys give me some advice on what I should inspect for and replace. The transmission was working fine when removed about 2 months ago with no leaks, grinding, noise etc. I not sure of it's previous history. Thanks Mike I actually would not take it apart! Just change the oil with 80/90 weight, and clean it up. If the trans happens to grind into a gear in the future it is easily removed with the engine in the car |
xperu Transmission Inspection Nov 1 2007, 01:30 PM
Cap'n Krusty Reasonable advice, to a point. As gear oil doesn... Nov 1 2007, 02:40 PM
Greenguy
Reasonable advice, to a point. As gear oil doesn... Nov 6 2007, 12:58 AM
Dr Evil Moly additives are inappropriate for the type of m... Nov 6 2007, 03:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 09:59 AM |
