> Rocker geo, hoe does this look to you guy's
toon1
post Oct 28 2007, 09:04 PM
so far the liift is good, cam card say's .426, I've got about .428.
Here is a pic. with the vave at half lift. Seems a little off(leaning back) to me.
toon1
post Nov 1 2007, 05:43 PM
thank's for the reply and the good info.
How many shims can I add?
There is already a .030 shim there, this made the geo much better. Can I add more or is it going to get too high?
Is the geo in the last pic. good or does it still need adjusting?
After laying the sraight edge accross all the valve tops and finding one was lower by.013 than the rest, what can be done or will it bee ok if the geo on that valve is done correct?
should I get a * wheel and check the valve timing you suggested?
thank's, Keith
toon1   Rocker geo   Oct 28 2007, 09:04 PM
toon1   here are somemore pics of the spacers. notice the ...   Oct 28 2007, 09:20 PM
toon1   one more   Oct 28 2007, 09:20 PM
Twystd1   Did you mill your rockers about 60 thou for those ...   Oct 28 2007, 11:16 PM
Joe Ricard   Hey what kinda push rod is that? Did you make on...   Oct 29 2007, 06:08 AM
TC.356   Shims beneath the rocker assemblies and longer (ad...   Oct 29 2007, 07:34 AM
toon1   Hey what kinda push rod is that? Did you make o...   Oct 29 2007, 09:29 AM
George H.   You mentioned oil for the rockers, should it ...   Oct 29 2007, 10:33 AM
orange914   I placed the dial indicator back into positio...   Nov 3 2007, 12:03 AM
craig downs   where axactly does the indicator go? wouldnt anyw...   Nov 3 2007, 12:48 AM
Joe Ricard   I oil the rocker shafts with the same oil I do eve...   Oct 29 2007, 10:26 AM
toon1   there is oil on the rocker shafts, I didnt' oi...   Oct 29 2007, 11:24 AM
Joe Ricard   What really want to know is how much of a clearanc...   Oct 29 2007, 11:44 AM
toon1   here are some more pics. I added .030 shims under ...   Oct 31 2007, 12:23 AM
toon1   2 more   Oct 31 2007, 12:24 AM
Twystd1   Uhhhh... 1) Are you setting up your rocker GEO at...   Oct 31 2007, 01:13 AM
toon1   Uhhhh... 1) Are you setting up your rocker GEO a...   Oct 31 2007, 11:15 AM
toon1   :bump: el bumpo thank's guy's   Oct 31 2007, 07:52 PM
Twystd1   Do me a favor..... Throw a straight edge across A...   Oct 31 2007, 08:47 PM
toon1   with the sraight edge on the tops of the valve ste...   Oct 31 2007, 10:20 PM
Twystd1   Your gaps are survivable. If ya want it perfect. ...   Nov 1 2007, 12:16 AM
craig downs   ahhhhh I guess its time to say something and proba...   Nov 1 2007, 01:29 AM
toon1   thank's guy's, I will give that a try. ...   Nov 1 2007, 09:59 AM
Joe Ricard   That extension thing on the Rocker adjuster is pur...   Nov 1 2007, 10:27 AM
Joe Ricard   Bump for the evening crowd. Obviously the day su...   Nov 1 2007, 03:39 PM
HAM Inc   The geometry in the last photo looked a lot better...   Nov 1 2007, 05:02 PM
toon1   thank's for the reply and the good info. H...   Nov 1 2007, 05:43 PM
Twystd1   Do not take any more than about 60 thou off the ro...   Nov 1 2007, 09:19 PM
Twystd1   CRAIG..... Post up pics of your PS tool / arrange...   Nov 1 2007, 09:28 PM
toon1   I took another .020 off the rocker. I got your pos...   Nov 1 2007, 11:18 PM
Twystd1   Since your engine was't machined perfectly to ...   Nov 1 2007, 11:45 PM
toon1   Since your engine was't machined perfectly to...   Nov 2 2007, 12:26 AM
craig downs   Ok I'll try to get some pics tomorrow. Hmmm p...   Nov 2 2007, 03:08 AM
Twystd1   TOON, A half a MM is way to much to average Do e...   Nov 2 2007, 02:27 PM
purple   I guess it's kindof a newbie question and all,...   Nov 2 2007, 03:33 PM
toon1   TOON, A half a MM is way to much to average Do ...   Nov 2 2007, 08:27 PM
Twystd1   Excellent job Keith.....!!!!!...   Nov 2 2007, 09:54 PM
toon1   DO those #'s look good? Thank's for the...   Nov 2 2007, 10:55 PM
Twystd1   Keith, YOU WILL HAVE TO START OVER ON YOUR GEO WI...   Nov 3 2007, 12:02 AM
toon1   Thank's Clayton, I'll wait till the cyl...   Nov 3 2007, 12:26 AM
Twystd1   To the guy that just PMed me about how to INSTALL...   Nov 3 2007, 01:00 AM
toon1   To the guy that just PMed me about how to INSTAL...   Nov 3 2007, 09:45 AM
HAM Inc   Been out of town for a few days, so I just got up ...   Nov 5 2007, 03:10 PM
- Lo-Fi Version Time is now: 2nd May 2026 - 08:25 AM
