Inside & backside door panels, rescue, refurbish & rejuvenate.....or pitch? |
1970 Neun vierzehn |
Oct 31 2007, 07:16 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
From my 70/4....original, but nasty on the back. Unless I've missed it somewhere, I've not seen any door panel resto threads. The backside of the panels are pretty grungy, which doesn't surprise, 'cause when I'd slam the doors closed, foam crap would fall out the bottom.
Suggestions? (IMG:style_emoticons/default/huh.gif) Attached image(s) |
JeffBowlsby |
Nov 1 2007, 12:23 AM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Interesting thread. On my 74 BB, there is a clear polyethylene moisture barrier. It has an attached polyethylene flap that is inserted into the lower inner door that shed any water to the door cavity, and not onto the interior upholstered panels. Does anyone else have these plastic sheet door liners?
Pat Garvey |
Nov 1 2007, 09:15 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Interesting thread. On my 74 BB, there is a clear polyethylene moisture barrier. It has an attached polyethylene flap that is inserted into the lower inner door that shed any water to the door cavity, and not onto the interior upholstered panels. Does anyone else have these plastic sheet door liners? I have them on my late '72. They are NOT to be underrated - they actually work & the backsides of my panels were perfect last year. This could be a fairly easily reproduced item. As I recall, the glue used to keep them in place was something very simple, such as rubber cement. Pat |
Lo-Fi Version | Time is now: 4th June 2024 - 04:45 AM |
