Inside & backside door panels, rescue, refurbish & rejuvenate.....or pitch? |
1970 Neun vierzehn |
Oct 31 2007, 07:16 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
From my 70/4....original, but nasty on the back. Unless I've missed it somewhere, I've not seen any door panel resto threads. The backside of the panels are pretty grungy, which doesn't surprise, 'cause when I'd slam the doors closed, foam crap would fall out the bottom.
Suggestions? (IMG:style_emoticons/default/huh.gif) Attached image(s) |
JeffBowlsby |
Nov 1 2007, 12:23 AM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Interesting thread. On my 74 BB, there is a clear polyethylene moisture barrier. It has an attached polyethylene flap that is inserted into the lower inner door that shed any water to the door cavity, and not onto the interior upholstered panels. Does anyone else have these plastic sheet door liners?
davep |
Nov 1 2007, 06:32 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
JeffBowlsby |
Nov 2 2007, 02:42 PM
[/quote]
As a matter of fact I have a NOS one in a bag. [/quote] Cool...It would be great to reproduce these. Given any consideration for making a pattern from your NOS part or would you lend it to me to make a pattern? It does look like rubber cemetn that holds them to the door. A waterbased glue would not last very long... |
Pat Garvey |
Nov 2 2007, 05:57 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
[quote name='Jeff Bowlsby' date='Nov 2 2007, 02:42 PM' post='963051']
[/quote] As a matter of fact I have a NOS one in a bag. [/quote] Cool...It would be great to reproduce these. Given any consideration for making a pattern from your NOS part or would you lend it to me to make a pattern? It does look like rubber cemetn that holds them to the door. A waterbased glue would not last very long... [/quote] Looks like rubber cement, balls up like rubber cement, but could be some other petro-based cement. However, it sure isn't white glue based. I use dilute white glue by the gallon in my model railroading hobby to hold all sorts of things, with no visiblity. Nice thing about it is, if you want to change something you just spritz it with water & it comes loose. Not something I want to happen to my 914 vapor barriers. Now, we ALL have old barriers & DaveP has a virgin one that could be used as a pattern for new. Hell, you could make new ones from just about anything heavier than dry clean plastic. I'd like some new ones, just because mine have been moved a bunch of times over the years to lube the regulators. How 'bout it? Can we get a pattern made? Pat |
Lo-Fi Version | Time is now: 29th May 2024 - 03:03 AM |
