| toon1 |
Oct 28 2007, 09:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
so far the liift is good, cam card say's .426, I've got about .428.
Here is a pic. with the vave at half lift. Seems a little off(leaning back) to me. Attached image(s)
| toon1 |
Oct 29 2007, 09:29 AM
Hey what kinda push rod is that? Did you make one out of an old stock one? ya know that the ball tip is a different size. and where it you oil for the rockers? them need to ne oiled or you will be really screwing things up. You dial indicator is not on in the same plane as the valve stem, it makes a difference. Just for reference my adjusters have 3-4 threads before bottoming out. Well you aked if it looks good Honesty sucks huh? The truth does NOT hurt in this case. I didn't post because I was proud of what I did, I thought something was wrong and needed help. I'm getting the answers I was looking for. Thank you! Yes, the p/r was made from a stock p/r. I drilled the ends and installed the correct tips. You mentioned oil for the rockers, should it be on the tips of the adjusters? I placed the dial indicator back into position for the pic but didn,t really alighn it well with the valve stem. When I am checking the lift I make sure it's alighned. It's good to know about the amount of threads that should be exposed. I did take the .060 off the rocker for clearance. I will try some shims this eve. thank's again, Keith |
| orange914 |
Nov 3 2007, 12:03 AM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
toon1 Rocker geo Oct 28 2007, 09:04 PM
toon1 here are somemore pics of the spacers. notice the ... Oct 28 2007, 09:20 PM
toon1 one more Oct 28 2007, 09:20 PM
Twystd1 Did you mill your rockers about 60 thou for those ... Oct 28 2007, 11:16 PM
Joe Ricard Hey what kinda push rod is that?
Did you make on... Oct 29 2007, 06:08 AM
TC.356 Shims beneath the rocker assemblies and longer (ad... Oct 29 2007, 07:34 AM
George H.
You mentioned oil for the rockers, should it ... Oct 29 2007, 10:33 AM
craig downs where axactly does the indicator go? wouldnt anyw... Nov 3 2007, 12:48 AM
Joe Ricard I oil the rocker shafts with the same oil I do eve... Oct 29 2007, 10:26 AM
toon1 there is oil on the rocker shafts, I didnt' oi... Oct 29 2007, 11:24 AM
Joe Ricard What really want to know is how much of a clearanc... Oct 29 2007, 11:44 AM
toon1 here are some more pics. I added .030 shims under ... Oct 31 2007, 12:23 AM
toon1 2 more Oct 31 2007, 12:24 AM
Twystd1 Uhhhh...
1) Are you setting up your rocker GEO at... Oct 31 2007, 01:13 AM
toon1
Uhhhh...
1) Are you setting up your rocker GEO a... Oct 31 2007, 11:15 AM
toon1 :bump: el bumpo thank's guy's Oct 31 2007, 07:52 PM
Twystd1 Do me a favor.....
Throw a straight edge across A... Oct 31 2007, 08:47 PM
toon1 with the sraight edge on the tops of the valve ste... Oct 31 2007, 10:20 PM
Twystd1 Your gaps are survivable.
If ya want it perfect. ... Nov 1 2007, 12:16 AM
craig downs ahhhhh I guess its time to say something and proba... Nov 1 2007, 01:29 AM
toon1 thank's guy's, I will give that a try.
... Nov 1 2007, 09:59 AM
Joe Ricard That extension thing on the Rocker adjuster is pur... Nov 1 2007, 10:27 AM
Joe Ricard Bump for the evening crowd.
Obviously the day su... Nov 1 2007, 03:39 PM
HAM Inc The geometry in the last photo looked a lot better... Nov 1 2007, 05:02 PM
toon1 thank's for the reply and the good info.
H... Nov 1 2007, 05:43 PM
Twystd1 Do not take any more than about 60 thou off the ro... Nov 1 2007, 09:19 PM
Twystd1 CRAIG.....
Post up pics of your PS tool / arrange... Nov 1 2007, 09:28 PM
toon1 I took another .020 off the rocker. I got your pos... Nov 1 2007, 11:18 PM
Twystd1 Since your engine was't machined perfectly to ... Nov 1 2007, 11:45 PM
toon1
Since your engine was't machined perfectly to... Nov 2 2007, 12:26 AM
craig downs Ok I'll try to get some pics tomorrow.
Hmmm p... Nov 2 2007, 03:08 AM
Twystd1 TOON,
A half a MM is way to much to average
Do e... Nov 2 2007, 02:27 PM
purple I guess it's kindof a newbie question and all,... Nov 2 2007, 03:33 PM
toon1
TOON,
Do ... Nov 2 2007, 08:27 PM
Twystd1 Excellent job Keith.....!!!!!... Nov 2 2007, 09:54 PM
toon1 DO those #'s look good?
Thank's for the... Nov 2 2007, 10:55 PM
Twystd1 Keith,
YOU WILL HAVE TO START OVER ON YOUR GEO WI... Nov 3 2007, 12:02 AM
toon1 Thank's Clayton, I'll wait till the cyl... Nov 3 2007, 12:26 AM
Twystd1 To the guy that just PMed me about how to INSTALL... Nov 3 2007, 01:00 AM
toon1
To the guy that just PMed me about how to INSTAL... Nov 3 2007, 09:45 AM
HAM Inc Been out of town for a few days, so I just got up ... Nov 5 2007, 03:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 08:25 AM |
