alpha434 |
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains ![]() |
On the wheel side. Driver side wheel. What parts do I need?
Went to Chipotle, made a right turn accelerating, and pop! Engine spins. CV spins. Wheel doesn't. (IMG:style_emoticons/default/wacko.gif) |
alpha434 |
Yep.
Bad day for my 914 to be my primary car. I can't see down into the trailing arm. But isn't that a splined shaft, anyway? Bolted in by the castle nut under the wheel??? |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Yep. Bad day for my 914 to be my primary car. I can't see down into the trailing arm. But isn't that a splined shaft, anyway? Bolted in by the castle nut under the wheel??? Not at the part where it would break. The most common area for these to go is at the shaft to transmission joint, but there is a reason why some reffer to these as fuses (IMG:style_emoticons/default/headbang.gif) They bolt on at both sides though. |
Lo-Fi Version | Time is now: 31st July 2025 - 05:25 PM |
