Wilwood Rear Parking Brake, New Comboination |
Van914 |
Nov 5 2007, 08:20 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Has anyone checked out Wilwoods Combination Parking Brake Caliper? It is a radial mount and has a 34mm bore. Might be a great way to get bigger brakes and keep the parking brake. Now if I could only source the brackets to mount to the tarailing arm.
http://www.wilwood.com/Products/001-Calipe...3-cpb/index.asp Van914 |
GS Guy |
Nov 5 2007, 05:14 PM
Member Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
You guys might be interested in this little gem - IPS mechanical caliper.
Got a set of these showing up this week and I'll be shelving my Wilwood mechanicals. To tell the truth - I'm surprised the Wilwoods don't bind or jam up anyway - the movable pad is basically just sitting loose in the caliper, with a loose steel plate behind it and loose pin behind that! Only careful adjustment on the rotor keeps this stuff from falling out! On top of that the sliding mount arrangement leaves much to be desired, IMO. Marty has apparently worked out the major issues with these - but once I saw these IPS calipers I knew for sure I wouldn't be using the Wilwoods! No comparison IMHO. The available mounting bracket (shown) contains a spring feature to keep the pads from dragging on the rotors when not in use. Integral sliding pins provide the necessary "float", and they bolt on just like a hydraulic caliper. They're sweeeet! http://www.ipsco.org/Custom%20Services/Parking%20Brake.htm Jeff |
Lo-Fi Version | Time is now: 10th June 2024 - 09:55 PM |
