Wilwood Rear Parking Brake, New Comboination |
Van914 |
Nov 5 2007, 08:20 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Has anyone checked out Wilwoods Combination Parking Brake Caliper? It is a radial mount and has a 34mm bore. Might be a great way to get bigger brakes and keep the parking brake. Now if I could only source the brackets to mount to the tarailing arm.
http://www.wilwood.com/Products/001-Calipe...3-cpb/index.asp Van914 |
ClayPerrine |
Nov 5 2007, 01:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,525 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You are going to find out what we already know. If you set the brake with the rotor hot, it won't release when it is cold. Mike Floyd had this setup on his 914, and he had to beat the calipers with a hammer to get them to release in the morning.
He now has a 911 style park brake. |
andys |
Nov 5 2007, 03:40 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
You are going to find out what we already know. If you set the brake with the rotor hot, it won't release when it is cold. Mike Floyd had this setup on his 914, and he had to beat the calipers with a hammer to get them to release in the morning. He now has a 911 style park brake. Clay, Do tell more. I haven't got my car on the ground yet, so you have my attention. Are you refering to the spot caliper, or the Wilwood combo unit? The combo units have been used on many thousands of American and I believe some foreign cars. Do they really have an issue with pads sticking to the rotors? I haven't heard of this before. Andys |
ClayPerrine |
Nov 5 2007, 07:36 PM
You are going to find out what we already know. If you set the brake with the rotor hot, it won't release when it is cold. Mike Floyd had this setup on his 914, and he had to beat the calipers with a hammer to get them to release in the morning. He now has a 911 style park brake. Clay, Do tell more. I haven't got my car on the ground yet, so you have my attention. Are you refering to the spot caliper, or the Wilwood combo unit? The combo units have been used on many thousands of American and I believe some foreign cars. Do they really have an issue with pads sticking to the rotors? I haven't heard of this before. Andys This is the Wilwood spot caliper. Wes Hildreth put a set on Mike's car with the Boxster rear calipers. It worked fine, but the calipers would lock up and not release. It was determined that the caliper was shifting in its bracket as the brakes cooled down. They even had a huge release spring on it to try to get it to release. No bueno, it never would work right. |
andys |
Nov 6 2007, 12:28 AM
You are going to find out what we already know. If you set the brake with the rotor hot, it won't release when it is cold. Mike Floyd had this setup on his 914, and he had to beat the calipers with a hammer to get them to release in the morning. He now has a 911 style park brake. Clay, Do tell more. I haven't got my car on the ground yet, so you have my attention. Are you refering to the spot caliper, or the Wilwood combo unit? The combo units have been used on many thousands of American and I believe some foreign cars. Do they really have an issue with pads sticking to the rotors? I haven't heard of this before. Andys This is the Wilwood spot caliper. Wes Hildreth put a set on Mike's car with the Boxster rear calipers. It worked fine, but the calipers would lock up and not release. It was determined that the caliper was shifting in its bracket as the brakes cooled down. They even had a huge release spring on it to try to get it to release. No bueno, it never would work right. Well since I aready have the Wilwood's mounted, I'll give em a try. I have a complete Carrera suspension to rob the parking brakes from should I encounter problems. Thanks for the heads up. Andys |
Lo-Fi Version | Time is now: 11th June 2024 - 09:21 AM |
