> horn button wiring, momo hub and steering wheel
will
post Apr 11 2007, 10:20 PM
licensed to kill
how do you hook up the wire for the horn button on a momo hub and steering wheel?
thanks,
will
srthompson01
post Apr 11 2007, 11:10 PM
Take the great big washer under the nut that holds steering wheel on, drll a very small hole as close as possible to the outer edge of the washer.
Get a spade connector and put on ground wire of horn button, the other side of the connector to a 4 inch ling piece of wire, strip an inch of insulation off of the other end of the wire and push though newly drilled hole an twist together to hold.
Take the push connector off of old horn button, connect to red wire on momo with a spade connector.
Turn on key and honk horn.
If it works, disconnect using spades, install mounting hub, tighten bolt over drilled washer, put on the steering wheel, connect horn button, and then bolt it down. If you don't have light hold loctite you can put a little fingernail polish on the threads.
Stephen
will
post Nov 6 2007, 11:39 PM
licensed to kill
QUOTE(srthompson01 @ Apr 11 2007, 09:10 PM) *
Stephen
Do you have a picture of this?
thanks,
will
- Lo-Fi Version Time is now: 1st August 2025 - 05:11 PM
