| URY914 |
Nov 6 2007, 10:28 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 135,480 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Every few years Hot VW's magazine does a Weber rebuild article. This time it is better than usual. The photos are all in color and there are 37 step by step photos. Very straight forward and easy to follow.
Pick in up at a Border's near you. |
| zig-n-zag |
Nov 7 2007, 02:00 AM
Member ![]() ![]() Group: Members Posts: 220 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
I'm in the process of rebuilding a set of 40 IDF's and when it came to setting the floats, the sketch in CB's Weber Tech Manual differ from my John Passini authored Weber Carburators Tuning and Maintenance. I have other references but the point is that the CB sketch show the float at 10mm from the carb cover and then it shows you ADD 32.5mm for the low float measurement. The Passini sketch shows the 10mm distance from cover to float, and 32.5mm distance from the cover to the low float position. The CB info would put the float 42.5mm from the carb cover!!!!!! Them CB MX's must have deep fuel bowls.....
URY914 Weber IDF rebuild article in Hot VW's Nov 6 2007, 10:28 PM
cooltimes Maybe this is a link you could use.
http://www.car... Nov 7 2007, 02:21 AM
zig-n-zag Cooltimes, Thanks I've visited there before. ... Nov 7 2007, 04:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st November 2026 - 11:19 PM |
