914 Rear Fog Lamp Installation with details & Photo's, Only winning cars have them, BLing, Bling. |
TJB/914 |
Jun 30 2007, 03:50 PM
Mid-Engn. Group: Members Posts: 4,336 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hi Guys,
I just finished drilling (2) 6mm holes & (1) 3mm hole in by trunk to mount my "Rear Fog Light" factory accessory. I like it, makes my car different from all the others. (IMG:style_emoticons/default/pray.gif) Here's a few pictures to show details of the U.S.A. issue rear fog lamp I installed. I got a Euro fog lamp assembly from Gustl (thanks Gustl-aka-Wolfgang) & put everything together using the satin black U.S. housing with the Euro lens because I thought it looked better. One of the brackets to mount is still available from Porsche, but the exterior bracket is NLA. The exterior bracket I got from Gustl was a surprise, it's made of stainless steel. I'll post a number of photo's in a few days showing lots of details & differences. (IMG:style_emoticons/default/popcorn[1].gif) Hope you guys enjoy. Tom BTW Pat: I measured a lot before drilling the holes. Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
Nov 7 2007, 04:11 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I picked up the harness last night, I am sure it will not be a problem to fab these up. Thanks Mike! (IMG:style_emoticons/default/smilie_pokal.gif) I do have some questions though:
1. the cockpit end is a 2.5mm male wire terminal, I am guessing it attaches to the fog light switch on the dash, can anyone verify before IO go tearing into my dash to confirm? Seem like an odd wire termional for that. 2. How does the harness attach to the fog light assembly? I assume it goes through rubber grommets in the tailpanel and foglight housing, but are both wires tinned and screwed down for the electrical connection or is there a terminal on each wire? I saw the photos in the early posts, they dont show the ground wire The only challenge I see is fishing 20 feet of wiring through 20 feet of heat shrink tubing... |
Lo-Fi Version | Time is now: 9th June 2024 - 11:35 PM |
