| slackin' at work |
Nov 8 2007, 02:37 PM
i should be working ![]() ![]() Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
my car has a 009 and I know it is not doing me any favors.
I NEED to replace it with something... and Im eventually going back to FI. so my question is, can I run a stock distributor with dual carbs? Should I take the trigger-points out until Im ready to go FI? of course I don't have the stock distributor, so before I buy one Id like to know if it's OK to run it until I make the swap. (IMG:style_emoticons/default/beer.gif) -chris |
| BarberDave |
Nov 9 2007, 05:20 AM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I use a 50 with a Petronics (sp) unit, with 40's since 2000 ,the only trouble was of my own makeing. I.E. left the ignition switch on burnt the Petronics out. Good luck Dave (IMG:style_emoticons/default/slap.gif) |
slackin' at work running stock distributor with carbs. Nov 8 2007, 02:37 PM
Travis Neff yes you can run a stock distributor, I'd leave... Nov 8 2007, 02:48 PM
anderssj I've heard that the stock distributor from a 1... Nov 8 2007, 02:49 PM
slackin' at work thanks guys for the thoughts.
I was just about to... Nov 8 2007, 03:53 PM
Mike914
I've heard that the stock distributor from a ... Nov 8 2007, 07:23 PM
andys When I made a Weber carb swap on my 2.0L some 30+ ... Nov 8 2007, 04:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 02:51 PM |
