> Oiling problems on sharp turns, Whats your oiling solution?
JPB
post Sep 29 2007, 07:56 AM
The Crimson Rocket smiles in your general direction.
Talking to some track dudes some have said they gave up driving T4s due to loosing to much oil on the track and no matter how big the Acusump was, they still burned out bearings. What is your solution to this problem? THNX (IMG:style_emoticons/default/beer.gif)
HAM Inc
post Nov 10 2007, 11:09 AM
Assuming you already have an adequate oil cooler plumbed up adding a dry sump may not cost as much as you think. A dry sump oil pump is available that fits in the stock location (alternate engine mounting bracket must be made. I have done this on the house F-Prod car for solid mounts) Used oil tanks can be had on e-bay for cheap. If the car is a dd that is occasionally ax, then an accusump is the way to go. If a dedicated track and/or ax car, I would go dry sump. It can be done for less than $500.00
JPB   Oiling problems on sharp turns   Sep 29 2007, 07:56 AM
Dave_Darling   My solution is two-fold: 1--tuna can 2--drive slo...   Sep 29 2007, 09:01 AM
JPB   Tuna can doable, driving slow, easier said than do...   Sep 29 2007, 09:13 AM
Dave_Darling   I dunno about that, but I just have lousy times......   Sep 29 2007, 05:46 PM
grantsfo   Think it depends on what your doing with the car. ...   Sep 29 2007, 06:11 PM
Joe Ricard   Dry sump   Sep 29 2007, 08:38 PM
JPB   Good advise bros/manziers. The PO had a 1 1/2 quar...   Sep 30 2007, 04:10 AM
TGM   A full deep sump was the only solution to complete...   Oct 21 2007, 09:32 PM
Krieger914   I have a simple solution that has worked well in m...   Oct 21 2007, 10:39 PM
Joe Ricard   Every 914 I have driven other than mine has been a...   Oct 22 2007, 04:12 PM
sww914   I've gotten by with a deep sump and a 2 qt acc...   Nov 8 2007, 12:40 AM
ChrisNPDrider   Ok - I'm hoping for input here for my particul...   Nov 9 2007, 06:14 PM
HAM Inc   Assuming you already have an adequate oil cooler p...   Nov 10 2007, 11:09 AM
hedfurst   Len, I have a deep sump that has fixed my problem...   Nov 10 2007, 08:11 PM
Joe Ricard   Who knows how to wire up a sensor/sendor to activa...   Nov 10 2007, 08:38 PM
hedfurst   Hmm. "Huge," =not really quantifiable, h...   Nov 10 2007, 11:54 PM
alpha434   Well... There is a port in 356 cases that all the...   Nov 11 2007, 01:39 AM
Twystd1   Joe, I have some more useless data for you. Back...   Nov 11 2007, 03:36 AM
zig-n-zag   JPB, The December 07 issue of Hot VWs has an arti...   Nov 11 2007, 05:28 AM
HAM Inc   The CB dry sump pump is compatible with pretty muc...   Nov 11 2007, 11:52 AM
hedfurst   The CB dry sump pump is compatible with pretty mu...   Nov 11 2007, 12:03 PM
HAM Inc   No issues with the cooling fan. We use a Vanagon s...   Nov 11 2007, 02:46 PM
Aaron Cox   please show a pic of your bracket Len, Thanks...   Nov 11 2007, 02:59 PM
hedfurst   Oh-boy, got to have it! I think that this is t...   Nov 11 2007, 04:41 PM
HAM Inc   Aaron I would be glad to snap a photo, but the par...   Nov 12 2007, 03:44 PM
hedfurst   Aaron I would be glad to snap a photo, but the pa...   Nov 12 2007, 04:42 PM
groot   Here's a shot of my simple attachment. Note th...   Nov 12 2007, 06:54 PM
HAM Inc   Fred the reason I recommend running the cooler the...   Nov 13 2007, 09:12 AM
Brett W   You really need to be running a three or four stag...   Nov 13 2007, 10:01 AM
hedfurst   [quote name='Brett W' date='Nov 13 200...   Nov 13 2007, 12:28 PM
race914   [quote name='Brett W' date='Nov 13 20...   Nov 13 2007, 02:03 PM
HAM Inc   There's no doubt that a multi stage dry sump s...   Nov 13 2007, 04:50 PM
race914   There's no doubt that a multi stage dry sump ...   Nov 13 2007, 05:12 PM
Brett W   Who cares how much one of the most important piece...   Nov 13 2007, 11:22 PM
HAM Inc   One must keep in mind that budgets for racers are ...   Nov 14 2007, 09:21 AM
jhadler   I think the CB setup looks like a great option tha...   Nov 14 2007, 11:50 AM
race914   I saw a clip on Speed once featuring "Alex Za...   Nov 14 2007, 12:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:40 PM
