914 Rear Fog Lamp Installation with details & Photo's, Only winning cars have them, BLing, Bling. |
TJB/914 |
Jun 30 2007, 03:50 PM
Mid-Engn. Group: Members Posts: 4,336 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hi Guys,
I just finished drilling (2) 6mm holes & (1) 3mm hole in by trunk to mount my "Rear Fog Light" factory accessory. I like it, makes my car different from all the others. (IMG:style_emoticons/default/pray.gif) Here's a few pictures to show details of the U.S.A. issue rear fog lamp I installed. I got a Euro fog lamp assembly from Gustl (thanks Gustl-aka-Wolfgang) & put everything together using the satin black U.S. housing with the Euro lens because I thought it looked better. One of the brackets to mount is still available from Porsche, but the exterior bracket is NLA. The exterior bracket I got from Gustl was a surprise, it's made of stainless steel. I'll post a number of photo's in a few days showing lots of details & differences. (IMG:style_emoticons/default/popcorn[1].gif) Hope you guys enjoy. Tom BTW Pat: I measured a lot before drilling the holes. Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
Nov 10 2007, 11:19 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So I understand there were two different housings, with two different connection arrangements. I only have the one harness which has two wires in it.
Dave, I can certainly just send you some of the single white/green stripe wire when I get it if that what you want, but it would not look stock. I think the best answer is to make the harness with both wires and let each person put whatever end terminal on it they need. The wire with a terminal on it would not fit through the hollow housing mount anyway, the terminal must have been installed later. I need help figuring out where to connect the switch end, it seems like it should attach the the foglight switch which has 3 male tabs on it. The harness has a MALE 1/4" wire terminal and will not attach. Maybe it goes to a piggyback connector on the fuseblock for the foglights? Then I am ready to start production... |
Lo-Fi Version | Time is now: 7th June 2024 - 07:39 AM |
