> Oiling problems on sharp turns, Whats your oiling solution?
JPB
post Sep 29 2007, 07:56 AM
The Crimson Rocket smiles in your general direction.
Talking to some track dudes some have said they gave up driving T4s due to loosing to much oil on the track and no matter how big the Acusump was, they still burned out bearings. What is your solution to this problem? THNX (IMG:style_emoticons/default/beer.gif)
Twystd1
post Nov 11 2007, 03:36 AM
You don't want to know... really.....
Joe,
I have some more useless data for you.
Back in my round "D" round days. We always had a BIG RED oil pressure light mounted on the top of the dash. As we had no time to look at a tach or any other gauges.
As we were usually door to door and our fellow drivers are pushing on our cars through the turns. Only when we were free of traffic for a second or two. Could we glance at the gauges.
The problem we encountered with the RED light was this.
A pressure switch Is just that. At a given pressure the switch stays open. Any pressure below that the switch closes and completes the circuit and the red light comes on.
In our case. That was typically at the end of a turn or when the engine was so hot the oil was like water. And the viscosity dropped like a hammer and we loose oil pressure.
The problem is that when the RED light (20 psi) went red. The engine had already hurt itself. Same with oil pressure gauges. They work even slower.
The only good thing about a pressure gauge or a low pressure red light was the driver had a sense of what was going on. Just not in real time.
Thats the caveat. NOT IN REAL TIME.
In essence. Damage may well have already occurred before the gauge/light has shown there is an issue. And as that issue repeats itself.
Something eventually breaks.
In the case of our V8s. Major oil pressure drops can happen and the pressure switch and the gauge will NEVER SEE IT. It happens too fast for the analog approach to get the info. And then the pressure will dam near instantly rise and get back to normal. This is often because 2 different issues.
1) Loss of oil to the pump.
2) Engine harmonics reacting on the oil pump which in turn makes the oil go into stasis. Thats right........ The gears are turning. Yet the pump ain't pumping.
It was only because of the generosity of an engineer that had REAL TIME pressure sensors and the ability to data log this did we find out this was true.
And since our class didn't allow dry sump oiling. Over the years. We figured out how to stop the oil pressure problesms. This is 18 year old data. Maybe some of this might help.
Below is a list of the things we did to mitigate oil pressure loss.
1) Crank scraper to keep oil in the pan. (Not applicable to our engines)
2) Blue printed Billet oil pump.
3) Custom windage trays with hinged areas to keep oil in the lowest part of the sump.
4) Oil pickup tube that was custom length and larger that stock.
5) Rifle drilled and/or honed ALL oiling passages in block. Also made soft radius's in ALL oil passages and lifter galleys wherever possible.
6) Kept as much oil out of the valve cover area that is humanly possible. We used spray bars for this. Also had restrictors in the push rods.
7) NEVER have more than 10 LBS per 1000 rpm. The rest is just a waste with our builds. Additional pressure just heats up the oil and wastes HP.
8) Bigger oil pans do NOTHING unless the pan configuration allows the oil to QUICKLY get back to the pickup point and pool at this low point.
9) Crank case breathing plays a part in oil control. High internal crank case pressure will aerate the liquid oil. As oil pumps don't work that well when trying to push a vapor and liquid at the same time. The bearings don't much like it either.
10) ONLY USE A RACE ENGINE, PURPOSE BUILT, OIL FILTER ON A RACE CAR....!!!!
Use full flow filtration with an oil filter that has NO internal bypass.
(Yes they make them)
The remote filter housing DOES have a bypass if the filter clogs or implodes.
If dry sump is an option for your class.
And it is a purpose built track car.
I think a fella would have to be nuts not to use it.
I hope there is something you might use in the above data.
Cheers,
Clayton
8)
JPB   Oiling problems on sharp turns   Sep 29 2007, 07:56 AM
Dave_Darling   My solution is two-fold: 1--tuna can 2--drive slo...   Sep 29 2007, 09:01 AM
JPB   Tuna can doable, driving slow, easier said than do...   Sep 29 2007, 09:13 AM
Dave_Darling   I dunno about that, but I just have lousy times......   Sep 29 2007, 05:46 PM
grantsfo   Think it depends on what your doing with the car. ...   Sep 29 2007, 06:11 PM
Joe Ricard   Dry sump   Sep 29 2007, 08:38 PM
JPB   Good advise bros/manziers. The PO had a 1 1/2 quar...   Sep 30 2007, 04:10 AM
TGM   A full deep sump was the only solution to complete...   Oct 21 2007, 09:32 PM
Krieger914   I have a simple solution that has worked well in m...   Oct 21 2007, 10:39 PM
Joe Ricard   Every 914 I have driven other than mine has been a...   Oct 22 2007, 04:12 PM
sww914   I've gotten by with a deep sump and a 2 qt acc...   Nov 8 2007, 12:40 AM
ChrisNPDrider   Ok - I'm hoping for input here for my particul...   Nov 9 2007, 06:14 PM
HAM Inc   Assuming you already have an adequate oil cooler p...   Nov 10 2007, 11:09 AM
hedfurst   Len, I have a deep sump that has fixed my problem...   Nov 10 2007, 08:11 PM
Joe Ricard   Who knows how to wire up a sensor/sendor to activa...   Nov 10 2007, 08:38 PM
hedfurst   Hmm. "Huge," =not really quantifiable, h...   Nov 10 2007, 11:54 PM
alpha434   Well... There is a port in 356 cases that all the...   Nov 11 2007, 01:39 AM
Twystd1   Joe, I have some more useless data for you. Back...   Nov 11 2007, 03:36 AM
zig-n-zag   JPB, The December 07 issue of Hot VWs has an arti...   Nov 11 2007, 05:28 AM
HAM Inc   The CB dry sump pump is compatible with pretty muc...   Nov 11 2007, 11:52 AM
hedfurst   The CB dry sump pump is compatible with pretty mu...   Nov 11 2007, 12:03 PM
HAM Inc   No issues with the cooling fan. We use a Vanagon s...   Nov 11 2007, 02:46 PM
Aaron Cox   please show a pic of your bracket Len, Thanks...   Nov 11 2007, 02:59 PM
hedfurst   Oh-boy, got to have it! I think that this is t...   Nov 11 2007, 04:41 PM
HAM Inc   Aaron I would be glad to snap a photo, but the par...   Nov 12 2007, 03:44 PM
hedfurst   Aaron I would be glad to snap a photo, but the pa...   Nov 12 2007, 04:42 PM
groot   Here's a shot of my simple attachment. Note th...   Nov 12 2007, 06:54 PM
HAM Inc   Fred the reason I recommend running the cooler the...   Nov 13 2007, 09:12 AM
Brett W   You really need to be running a three or four stag...   Nov 13 2007, 10:01 AM
hedfurst   [quote name='Brett W' date='Nov 13 200...   Nov 13 2007, 12:28 PM
race914   [quote name='Brett W' date='Nov 13 20...   Nov 13 2007, 02:03 PM
HAM Inc   There's no doubt that a multi stage dry sump s...   Nov 13 2007, 04:50 PM
race914   There's no doubt that a multi stage dry sump ...   Nov 13 2007, 05:12 PM
Brett W   Who cares how much one of the most important piece...   Nov 13 2007, 11:22 PM
HAM Inc   One must keep in mind that budgets for racers are ...   Nov 14 2007, 09:21 AM
jhadler   I think the CB setup looks like a great option tha...   Nov 14 2007, 11:50 AM
race914   I saw a clip on Speed once featuring "Alex Za...   Nov 14 2007, 12:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:39 PM
