> there should be a classic thread, explaining 911 front suspension conversions
jimkelly
post Nov 11 2007, 08:12 AM
Delaware USA
what years fit 914?
what is the first year 911 had vented rotors?
which 911 struts bolt directly onto 914 suspension?
and the differences between different year 911 front suspensions?
thanks
jim
BTW - brad at 914club is selling billet 4 lug hubs for vented rotors $425 set - tempting for sure.
Eric_Shea
post Nov 11 2007, 03:37 PM
PMB Performance
Speak of the devil... here I come (IMG:style_emoticons/default/happy11.gif)
From reading this I take it my '70 914/6 is mostly the same as similar vintage 911 setups save for the different style parking brake?
Well, in saying that you tend to marry front and rear suspensions and then the answer is no. The rear suspension, because of our mid-engine configuration, is totally different from a 911. It is all 914 with the exception of calipers, rotors, hubs and stub axles (CV's and axles too) When you get down to basics, yes... 48mm pistons, same calipers up front and both share 38mm pistons in the rear albeit on totally different calipers.
You're about 99% accurate on the front end. The only difference I can see between a 1970 911T front end and a 1970 914-6 front end is the torsion bars. The 914-6 has special torsion bars that have the spline count of a 911 yet the spring rate of a 914.
NOW... why they simply didn't use 914 A-arms is beside me. It could very well be these suspension modules came "complete" and for economies of scale, they would be interchangable with the 911 bits. I have a factory video from that period which shows them installing a front suspension complete (brakes, struts etc.) on a 911. So, I would guess they simply used a completed 911 front suspension spec'd with 914-6 17mm weighted bars.
John is right... simply take these bolts out yank/replace and install those bolts. No conversion could be more straight forward. However, there are a few "varieties" to choose from.
I like to keep 914 a-arms for street and narrow bodied cars. This means you can probably get by with a simple strut purchase and swap. If you're going road racing I like the 911 arms as they afford a larger variety of t-bars.
I like 911T Boge struts (914-6 struts) for street and/or narrow cars and either vintage Koni/Bilstein struts with the 3.5" ears or later Boge with the 3.5" ears for wide body/racing cars. Also, get the a-arms for wide/racing cars as explained above. The 3.5" spacing allows the use of many upgraded calipers (S, A, Carrera etc.)
There probably should be a well defined list available for those interested in this fairly common process. I agree.
Basically: Emulate a 914-6 if you want a nice set-up for a narrow bodied street car and, emulate a 914-6/GT for more advanced use and performance. (IMG:style_emoticons/default/wink.gif)
jimkelly   there should be a classic thread   Nov 11 2007, 08:12 AM
lotus_65   There's some good info on the Pelican site. I...   Nov 11 2007, 08:19 AM
jimkelly   thanks jim   Nov 11 2007, 09:14 AM
smontanaro   There's some good info on the Pelican site. F...   Nov 11 2007, 09:36 AM
flesburg   Probably the reason no one has is because they are...   Nov 11 2007, 09:34 AM
Richard Casto   While researching the purchase of my 911 front sus...   Nov 11 2007, 09:56 AM
JPB   Easy enough and yes birdboard has all the info. I...   Nov 11 2007, 02:47 PM
neo914-6   what years fit 914? what is the first year 911 h...   Nov 11 2007, 03:30 PM
Air_Cooled_Nut   There are tons of threads here on this subject, s...   Nov 11 2007, 06:25 PM
neo914-6   [quote name='neo914-6' post='965676' date='N...   Nov 18 2007, 03:05 AM
Air_Cooled_Nut   ...I have thought about it and have occasionally d...   Nov 18 2007, 04:50 PM
Eric_Shea   Speak of the devil... here I come :evilgrin: ...   Nov 11 2007, 03:37 PM
McMark   BTW - brad at 914club is selling billet 4 lug hubs...   Nov 11 2007, 07:27 PM
jimkelly   my proposed alt solution http://www.914world.com/...   Nov 11 2007, 08:39 PM
John   I prefer the latest (up to 1989) 911 front suspens...   Nov 11 2007, 08:41 PM
Blood red 914-6gt   Eric Don't you suppose the reason they used a...   Nov 12 2007, 01:10 PM
Brando   It's easy... Remove wheels. Unbolt A-arms and...   Nov 12 2007, 02:28 PM
Cap'n Krusty   You really wouldn't want to use 1965-1968 stru...   Nov 12 2007, 02:43 PM
Aaron Cox   and avoid hydro pneumatic struts!   Nov 12 2007, 03:58 PM
porsche913b_sp   and avoid hydro pneumatic struts! speaking ...   Nov 18 2007, 12:46 AM
Eric_Shea   Yes. But, what makes you think they are hydros?...   Nov 18 2007, 10:51 AM
914pwer   It's easy... Remove wheels. Unbolt A-arms an...   Nov 22 2007, 05:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:25 AM
