944 Calipers - Master Cyl? |
Enigma |
Nov 12 2007, 12:03 PM
Newbie Group: Members Posts: 34 Joined: 4-November 07 From: Ontario Canada Member No.: 8,298 |
Hello,
My 73 914 has been fitted with 911 rotors and 944 calipers. The guy installed the 944 vaccum brake booster and master cylinder in the spare tire well of this car. Needless to say, I am not impressed with his conversion. I wish to remove the power brake booster and install the master cylinder back where it belongs. My Question is, will the 944 master cylinder thats is currently attached to the brake booster bolt into the original 914 mount? If not what master will bolt up to the 914 and work with the 944 calipers? Cheers |
Brando |
Nov 12 2007, 01:59 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Your engine probably doesn't create enough vacuum to work properly with that booster.
Go to a 19mm MC, $75-$150. Should work good with the brake setup you have. Expect to push harder on the pedal though. What kind of pads are you running, also? That will have an effect on your car's braking as well. |
Lo-Fi Version | Time is now: 6th June 2024 - 08:13 PM |
