> Oiling problems on sharp turns, Whats your oiling solution?
JPB
post Sep 29 2007, 07:56 AM
The Crimson Rocket smiles in your general direction.
Talking to some track dudes some have said they gave up driving T4s due to loosing to much oil on the track and no matter how big the Acusump was, they still burned out bearings. What is your solution to this problem? THNX (IMG:style_emoticons/default/beer.gif)
HAM Inc
post Nov 12 2007, 03:44 PM
Aaron I would be glad to snap a photo, but the part is on the car and I can't get an angle that will show it. Next time I have it off I'll snap a shot of it.
Fred the link shows the plumbing diagram for the CB pump. I would suggest not routing into the cooler as it shows. Use what ever you currently have set-up. You will need to run a pipe tap into the pump body to enlarge the existing threads. For some reason they are under machined. Perhaps so the installer can ensure the nipple he uses fits properly. Use black pipe, not brass as the brass can crack.
http://www.cbperformance.com/images/DSOPSHU.jpg
Jake said he is developing a dry sump pump that will work similar to this one, but I'm sure it will be a better piece. We have not heard of any problems with the CB pump, but it can be improved upon.
hedfurst
post Nov 12 2007, 04:42 PM
QUOTE(HAM Inc @ Nov 12 2007, 01:44 PM) *
Cool, why do you recommend not routing through the cooler?
Have you completely eliminated the factory filter/cooler? I am currently using a wafer adaptor for my ext. cooler.
The CB tank offering holds 12q, what is the volume that you use?
Also, I would like one of your mounts, just let me know what $ to send you.
thanks Len,
Fred
JPB   Oiling problems on sharp turns   Sep 29 2007, 07:56 AM
Dave_Darling   My solution is two-fold: 1--tuna can 2--drive slo...   Sep 29 2007, 09:01 AM
JPB   Tuna can doable, driving slow, easier said than do...   Sep 29 2007, 09:13 AM
Dave_Darling   I dunno about that, but I just have lousy times......   Sep 29 2007, 05:46 PM
grantsfo   Think it depends on what your doing with the car. ...   Sep 29 2007, 06:11 PM
Joe Ricard   Dry sump   Sep 29 2007, 08:38 PM
JPB   Good advise bros/manziers. The PO had a 1 1/2 quar...   Sep 30 2007, 04:10 AM
TGM   A full deep sump was the only solution to complete...   Oct 21 2007, 09:32 PM
Krieger914   I have a simple solution that has worked well in m...   Oct 21 2007, 10:39 PM
Joe Ricard   Every 914 I have driven other than mine has been a...   Oct 22 2007, 04:12 PM
sww914   I've gotten by with a deep sump and a 2 qt acc...   Nov 8 2007, 12:40 AM
ChrisNPDrider   Ok - I'm hoping for input here for my particul...   Nov 9 2007, 06:14 PM
HAM Inc   Assuming you already have an adequate oil cooler p...   Nov 10 2007, 11:09 AM
hedfurst   Len, I have a deep sump that has fixed my problem...   Nov 10 2007, 08:11 PM
Joe Ricard   Who knows how to wire up a sensor/sendor to activa...   Nov 10 2007, 08:38 PM
hedfurst   Hmm. "Huge," =not really quantifiable, h...   Nov 10 2007, 11:54 PM
alpha434   Well... There is a port in 356 cases that all the...   Nov 11 2007, 01:39 AM
Twystd1   Joe, I have some more useless data for you. Back...   Nov 11 2007, 03:36 AM
zig-n-zag   JPB, The December 07 issue of Hot VWs has an arti...   Nov 11 2007, 05:28 AM
HAM Inc   The CB dry sump pump is compatible with pretty muc...   Nov 11 2007, 11:52 AM
hedfurst   The CB dry sump pump is compatible with pretty mu...   Nov 11 2007, 12:03 PM
HAM Inc   No issues with the cooling fan. We use a Vanagon s...   Nov 11 2007, 02:46 PM
Aaron Cox   please show a pic of your bracket Len, Thanks...   Nov 11 2007, 02:59 PM
hedfurst   Oh-boy, got to have it! I think that this is t...   Nov 11 2007, 04:41 PM
HAM Inc   Aaron I would be glad to snap a photo, but the par...   Nov 12 2007, 03:44 PM
hedfurst   Aaron I would be glad to snap a photo, but the pa...   Nov 12 2007, 04:42 PM
groot   Here's a shot of my simple attachment. Note th...   Nov 12 2007, 06:54 PM
HAM Inc   Fred the reason I recommend running the cooler the...   Nov 13 2007, 09:12 AM
Brett W   You really need to be running a three or four stag...   Nov 13 2007, 10:01 AM
hedfurst   [quote name='Brett W' date='Nov 13 200...   Nov 13 2007, 12:28 PM
race914   [quote name='Brett W' date='Nov 13 20...   Nov 13 2007, 02:03 PM
HAM Inc   There's no doubt that a multi stage dry sump s...   Nov 13 2007, 04:50 PM
race914   There's no doubt that a multi stage dry sump ...   Nov 13 2007, 05:12 PM
Brett W   Who cares how much one of the most important piece...   Nov 13 2007, 11:22 PM
HAM Inc   One must keep in mind that budgets for racers are ...   Nov 14 2007, 09:21 AM
jhadler   I think the CB setup looks like a great option tha...   Nov 14 2007, 11:50 AM
race914   I saw a clip on Speed once featuring "Alex Za...   Nov 14 2007, 12:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:40 PM
