| JPB |
Sep 29 2007, 07:56 AM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Talking to some track dudes some have said they gave up driving T4s due to loosing to much oil on the track and no matter how big the Acusump was, they still burned out bearings. What is your solution to this problem? THNX (IMG:style_emoticons/default/beer.gif)
| Brett W |
Nov 13 2007, 10:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None
You really need to be running a three or four stage pump to get the maximum benefit from a drysump system. The valve covers hold a bunch of oil and you have to be able to suck that oil out and not wait for gravity to takes its effect and it drain back to the sump.
If you look at real race engines you will see at least three and four pickups on the suction side. On the V8s oil is sucked from each valve cover, the oil pan, and the lifter valley. The CB system doesn't do that. It pulls from one place, the place where the T4 has all the problems to begin with. |
| hedfurst |
Nov 13 2007, 12:28 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
[quote name='Brett W' date='Nov 13 2007, 08:01 AM' post='966229']
You really need to be running a three or four stage pump to get the maximum benefit from a drysump system. The valve covers hold a bunch of oil and you have to be able to suck that oil out and not wait for gravity to takes its effect and it drain back to the sump. If you look at real race engines you will see at least three and four pickups on the suction side. Makes sense to me. thanks len. What exactly is a 3 or 4 stage pump? Multiple pick-ups or multiple pumps? There's not really alot of space in a 914 for a much bigger/longer pump. How many pickups in a 911? I've never seen the inside of one. What's their sump tank volume? |
JPB Oiling problems on sharp turns Sep 29 2007, 07:56 AM
Dave_Darling My solution is two-fold:
1--tuna can
2--drive slo... Sep 29 2007, 09:01 AM
JPB Tuna can doable, driving slow, easier said than do... Sep 29 2007, 09:13 AM
Dave_Darling I dunno about that, but I just have lousy times...... Sep 29 2007, 05:46 PM
grantsfo Think it depends on what your doing with the car. ... Sep 29 2007, 06:11 PM
Joe Ricard Dry sump Sep 29 2007, 08:38 PM
JPB Good advise bros/manziers. The PO had a 1 1/2 quar... Sep 30 2007, 04:10 AM
TGM A full deep sump was the only solution to complete... Oct 21 2007, 09:32 PM
Krieger914 I have a simple solution that has worked well in m... Oct 21 2007, 10:39 PM
Joe Ricard Every 914 I have driven other than mine has been a... Oct 22 2007, 04:12 PM
sww914 I've gotten by with a deep sump and a 2 qt acc... Nov 8 2007, 12:40 AM
ChrisNPDrider Ok - I'm hoping for input here for my particul... Nov 9 2007, 06:14 PM
HAM Inc Assuming you already have an adequate oil cooler p... Nov 10 2007, 11:09 AM
hedfurst Len,
I have a deep sump that has fixed my problem... Nov 10 2007, 08:11 PM
Joe Ricard Who knows how to wire up a sensor/sendor to activa... Nov 10 2007, 08:38 PM
hedfurst Hmm.
"Huge," =not really quantifiable, h... Nov 10 2007, 11:54 PM
alpha434 Well...
There is a port in 356 cases that all the... Nov 11 2007, 01:39 AM
Twystd1 Joe,
I have some more useless data for you.
Back... Nov 11 2007, 03:36 AM
zig-n-zag JPB, The December 07 issue of Hot VWs has an arti... Nov 11 2007, 05:28 AM
HAM Inc The CB dry sump pump is compatible with pretty muc... Nov 11 2007, 11:52 AM
hedfurst
The CB dry sump pump is compatible with pretty mu... Nov 11 2007, 12:03 PM
HAM Inc No issues with the cooling fan. We use a Vanagon s... Nov 11 2007, 02:46 PM
Aaron Cox please show a pic of your bracket Len,
Thanks... Nov 11 2007, 02:59 PM
hedfurst Oh-boy, got to have it! I think that this is t... Nov 11 2007, 04:41 PM
HAM Inc Aaron I would be glad to snap a photo, but the par... Nov 12 2007, 03:44 PM
hedfurst
Aaron I would be glad to snap a photo, but the pa... Nov 12 2007, 04:42 PM
groot Here's a shot of my simple attachment. Note th... Nov 12 2007, 06:54 PM
HAM Inc Fred the reason I recommend running the cooler the... Nov 13 2007, 09:12 AM
race914
[quote name='Brett W' date='Nov 13 20... Nov 13 2007, 02:03 PM
HAM Inc There's no doubt that a multi stage dry sump s... Nov 13 2007, 04:50 PM
race914
There's no doubt that a multi stage dry sump ... Nov 13 2007, 05:12 PM
Brett W Who cares how much one of the most important piece... Nov 13 2007, 11:22 PM
HAM Inc One must keep in mind that budgets for racers are ... Nov 14 2007, 09:21 AM
jhadler I think the CB setup looks like a great option tha... Nov 14 2007, 11:50 AM
race914 I saw a clip on Speed once featuring "Alex Za... Nov 14 2007, 12:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:42 PM |
