Should I check the fuel pressure?, Just got the engine started and cam broke in... |
Bogaat |
Nov 12 2007, 10:32 AM
Member Group: Members Posts: 195 Joined: 8-January 07 From: Charleston, SC Member No.: 7,436 |
I was having issues starting my 74 w/ newly built 2.0 w/ Djet and figured out my fuel pump went bad on me. I bought a newer 75-76 style (way cheaper) and it cranked right up. I broke in the cam, set the timing/idle and am installing my CVs so I can take this thing for a ride! It cranks right up and runs smooth...but it does seem to kick out a little black smoke when it is warm (white when first cranked, but it is cold out). Do I need to check the fuel pressure since I installed a new pump? Anything else to check? Could it be I just need to run this thing around the block for a bit? Thanks guys!
(IMG:style_emoticons/default/beer3.gif) |
toon1 |
Nov 13 2007, 03:20 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Ok kids... I stopped by and grabbed a pressure kit from Harbor freight on sale for 9 bucks (IMG:style_emoticons/default/beerchug.gif) . Pressure was sitting steady at 36, so I adjusted it down to 30. I will crank it up after a few other tasks to see if the black smoke is gone Thanks guys (IMG:style_emoticons/default/beer3.gif) @ 36 psi you increased the flow rat of the inj. by 73cc/min. YEP! that'll make her run rich. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 02:25 AM |
