| neo914-6 |
Nov 13 2007, 12:08 AM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Electric "hybrid" Porsche
![]() Tesla's comparison to their new roadster, Porschius. Not sure what the aircraft above it represents... ![]() |
| byndbad914 |
Nov 14 2007, 06:47 PM
shoehorn and some butter - it fits ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
If pollution is the issue, electric cars are NOT the answer. Look what it takes to make the electricity... CO still uses coal to generate power, I mean, c'mon. Until this country rethinks power generation and begins converting all power generation to nuclear, I wouldn't waste a dime on an electric car from a pollution standpoint.
Then, cost-wise, they are not worth it either. Let alone run time/distance between charges and how friggin' small the cars are (smaller is better in that arena). A turbo, high pressure lean-burn diesel hybrid on the other hand... now we are talking. You could make a huge F250 diesel get close to 30mpg pretty easy with a hybrid option for cruising speed. The 4x4 crew cab long bed monsters get 18-20mpg on the highway as is, so working the technology to a leaner mix, or considering a valved 2-stroke with separately compressed charge (technology that is out there in the works that burns very lean and clean), etc with a hybrid setup could really be amazing. Cars averaging 75mpg pretty easily and don't have to be little shit-boxes like the Prius (my friend has one; couldn't give it to me). I am talking the 40mpg Audis and so forth getting around 75mpg. Then invade and take over Canada (would be an easier fight than in the mid-East) and drill like crazy (Canada has a lot of untapped oil) (IMG:style_emoticons/default/ph34r.gif) (IMG:style_emoticons/default/laugh.gif) |
| smontanaro |
Nov 14 2007, 09:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
If pollution is the issue, electric cars are NOT the answer. Look what it takes to make the electricity... CO still uses coal to generate power, I mean, c'mon. Until this country rethinks power generation and begins converting all power generation to nuclear, I wouldn't waste a dime on an electric car from a pollution standpoint. Maybe in Colorado they use a lot of coal, but it's hardly the only source of energy to create electricity, and in some states, like California, it generates well under half the electricity, according to Tesla's website. In Illinois I think about half the electricity is generated using coal. While electricity generated from coal isn't the final answer, it's certainly a step in the right direction and you have the option of improving your electricity generation mix as time goes on. That's not likely to happen to a great degree with the internal combustion engine, in diesel or gasoline form. Skip |
| byndbad914 |
Nov 15 2007, 04:27 PM
If pollution is the issue, electric cars are NOT the answer. Look what it takes to make the electricity... CO still uses coal to generate power, I mean, c'mon. Until this country rethinks power generation and begins converting all power generation to nuclear, I wouldn't waste a dime on an electric car from a pollution standpoint. Maybe in Colorado they use a lot of coal, but it's hardly the only source of energy to create electricity, and in some states, like California, it generates well under half the electricity, according to Tesla's website. In Illinois I think about half the electricity is generated using coal. While electricity generated from coal isn't the final answer, it's certainly a step in the right direction and you have the option of improving your electricity generation mix as time goes on. That's not likely to happen to a great degree with the internal combustion engine, in diesel or gasoline form. Skip Skip, look at that chart and look at the percentage in CA alone created by coal and natural gas. That is just absolutely wrong. Look how little nuclear. Nuclear energy is really the safest and cleanest form of power production period. Even hydro tends to introduce pollutants into the water (oils from bearings and so forth end up in the water). the fact that ANY energy is created in this modern age from coal and natural gas is proof that we are truly idiots on this subject in this country. People freak out when they think of nuclear power and compare it to a bomb, which are only comparable if you have a system of logic similar to Michael Moore. |
| swl |
Nov 15 2007, 04:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Nuclear energy is really the safest and cleanest form of power production period. While I agree whole heartedly with you, nuclear is not the long term answer either. The pollutants from uranium mining are a very real problem with no easy solution. Long term storage of spent fuel rods is not easy either but it is at least managable. The real problem is that there is a very finite amount of uranium around - we can consume that almost as fast as we consume oil. |
neo914-6 Hybrid Porsches Nov 13 2007, 12:08 AM
LarryR
[url=http://green.yahoo.com/blog/ecogeek/153/pors... Nov 13 2007, 12:36 AM
thomasotten I'm curious what is going to happen with the h... Nov 13 2007, 06:04 AM
BiG bOgGs
I'm curious what is going to happen with the ... Nov 13 2007, 06:14 AM
zymurgist
The best way to conserve on energy, it seems to m... Nov 13 2007, 09:59 AM
Joe Ricard Hell if people would just put air in thier tires w... Nov 13 2007, 06:15 AM
TeenerTim Why a hybrid? Just go all electric like these two ... Nov 13 2007, 08:37 AM
racunniff
Why a hybrid? Just go all electric like these two... Nov 13 2007, 10:24 AM
smontanaro Most of us use lead-acid batteries, which weigh a ... Nov 13 2007, 08:24 PM
LarryR
I'm curious what is going to happen with the... Nov 13 2007, 09:16 AM
Cap'n Krusty The Jetta's been bumped to late summer .......... Nov 13 2007, 09:33 AM
Brett W Even now it is cheaper to operate a vehicle on gas... Nov 13 2007, 10:22 AM
LarryR
The Jetta's been bumped to late summer ......... Nov 13 2007, 10:43 AM
Vacca Rabite
Tesla's comparison to their new roadster, Po... Nov 13 2007, 11:03 AM
Mid_Engine_914 Warum mit da hybrids?
ECONOMY
"The Aud... Nov 13 2007, 12:43 PM
BahnBrenner914 The best way to make what we already have more eff... Nov 13 2007, 12:46 PM
BMXerror Everyone seems to be forgetting that cars aren... Nov 13 2007, 01:26 PM
sww914
Everyone seems to be forgetting that cars aren... Nov 13 2007, 08:59 PM
neo914-6 We can debate maximum efficiency or best methods, ... Nov 13 2007, 02:54 PM
Brando Everyone should ride motorcycles. Even better, LPG... Nov 13 2007, 03:39 PM
Brett W I could give a shit about global warming. Don... Nov 13 2007, 07:50 PM
kwales If we could wean people off of gas wasting automat... Nov 13 2007, 08:31 PM
thomasotten Our country is at odds with itself. We don't ... Nov 13 2007, 09:53 PM
hydroliftin
[url=http://green.yahoo.com/blog/ecogeek/153/pors... Nov 13 2007, 10:18 PM
LarryR I am not sure about the rest of the country but in... Nov 13 2007, 11:27 PM
mudfoot76
The thing that drives me insane is the rediculous... Nov 14 2007, 08:23 AM
smontanaro I too would buy a MINI D. Three years ago I almost... Nov 14 2007, 09:00 AM
mudfoot76
The crash testing for diesel versions of Jettas ... Nov 14 2007, 09:45 AM
thomasotten Yep, it's kinda ironic when you consider that ... Nov 14 2007, 07:00 AM
Vacca Rabite If I could get a Mini D I would SO jump on it.
... Nov 14 2007, 10:10 AM
Demick I was looking at the specs for the new 1 series BM... Nov 14 2007, 10:11 AM
nukepipe this is what i'm waiting for....
http://www.... Nov 14 2007, 12:54 PM
Brando this is what i'm waiting for....
http://www.a... Nov 14 2007, 08:56 PM
Garold Shaffer OK, dumb question. Besides cost is there any reaso... Nov 14 2007, 02:28 PM
racunniff
[quote name='byndbad914' post='966810' date='Nov ... Nov 15 2007, 12:23 PM
andys
[quote name='byndbad914' post='966810' date='Nov... Nov 15 2007, 01:16 PM
swl
[quote name='byndbad914' post='966810' date='Nov... Nov 15 2007, 04:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:23 AM |
