| jamara |
Nov 14 2007, 03:51 PM
Member ![]() ![]() Group: Members Posts: 63 Joined: 27-February 06 From: LA, CA Member No.: 5,645 |
Well, I am not engineer, but I’ve got a harebrained idea for reinforcing the longs of the 914. I want to run it by you more experienced engineering types out there.
Theory: 1. Engman’s kit strategically places steel on the longs and lower firewall. Why? Because two pieces of sheet steel welded face to face are stronger than one by itself. 2. However, two pieces of sheet steel, separated and firmly affixed to a lighter weight material (fiber, honeycomb, thermopolymer, etc), is exponentially stronger than two pieces of steel welded together. Here is a site with more than you ever wanted to know about composite sandwich materials. The section at the bottom under "Core Materials for Sandwich Structures" is what you want. Pics at the bottom are a good illustration of the principle. http://www.mdacomposites.org/mda/psgbridge..._materials.html 3. A similar technology is being used on modern cars during their production. They put polyurethane pour foam into the A and B pillars, as well as the rockers of new cars. It deadens sound and really makes the chassis rigid. Here is a link to a “tuner” car that this was done to. Look under “Foam filling the chassis” http://www.sportcompactcarweb.com/projectc...rt_5/index.html 4. In terms of applying this to the 914 longs (putting pour foam in them), RUST is the deal killer. The longs on my car are “rust free” but still have some surface rust inside. With solid material in them to trap moisture, this could become a major problem. Also, the longs are fairly voluminous and so cost for foam and the resulting weight is another issue. So, here is my proposed solution. (IMG:http://www.fc.biola.edu/~james.calley/long_modification.jpg) This would involve welding ½” x ½” ½” tube steel to the inner long in a lattice configuration. Then as with the engman kit, preformed sheet steel (18g) would be rosette welded to the ½” tube steel pieces, to the floor pan, and to the upper door sill seam where the inner and outer long meet. This would leave a ½” gap between the inner long and the “skin” The lower firewall would simply have steel added like the Engman kit, or perhaps this sandwich method could be used. Now the good part…. 8lb per cubic foot polyurethane foam could be mixed and poured into the ½” gap on the inner long. There would need to be evacuation points for the urethane foam so that when it expands it doesn't blow the welds. Advantages: 1. Only 2.7 lbs extra weight in polyurethane given about 1/3rd cubic foot for both sides 2. Since we are dealing with the face of the inner long, it could be cleaned, phosphatized, Por-15’ed, gold plated, whatever, before everything is buttoned up. No rust issues. 3. Extreme rigidity since sandwich materials like this apparently behave like monolithic (solid) structures . In other words, it would be like having a huge 1/4" thick Engman kit with a fraction of the weight. 4. Only ½” invading the cabin area, as opposed to a roll cage. Problems: Relocation of the E-brake handle to the center console and possibly the back pad not fitting quite right. Also, the speaker grills in the front would need modifying. The ½” is not much but could cause problems here. Plus, my proposed design is to attach the top of the “skin” to the ½” lip at the top of the door sill where the inner and outer long are spot welded together. This is the area where the lower, inner door seal slips on and is held in place. Therefore, the trim piece that goes here would not fit without modification and the seal would need to be modified as well. Last thing, the seat belt bolt holes might need to be moved to the floor pan. Anyway, this is just an idea, so don’t anyone start foaming at the mouth over it. (I will discretely NOT add a link to the 914world forum topic on the subject of pour foam in the longs, where someone started typing obscenities and colorful metaphors over the matter.) What do you think…? |
| Jeff Hail |
Nov 16 2007, 01:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Something that needs to be brought up. If a chassis is altered and made to be too stiff and rigid it will tear itself apart. If you take a 914 and make the center section so stiff and rigid the rear (behind the firewall) and from the (cowl forward at the lower longs and hinge pillar's) become the soft flexible weak links. A chassis as a whole needs to be made equally rigid across the platform or stress's are transferred to other area's that may eventually fail and most likely will. From an engineering standpoint this would mean extending rigidity,additional stiffening and crossbracing from the center of the chassis to both front and rear suspension control points up to at least the towers. This can be done by truss (aka roll cage with tubes parallel and triangulated uprights from the horizontal plane)
The area from the firewall back (rear longs that go upright to the shock towers are like levers). They are designed to rise and fall with body flex, suspension compression from normal road undulations. They also provide controlled deformation (upward) in a collision. This flex is transmitted into the mid longs or torque box at the firewall junction and rockers. If you look at the 914 design you will see that this is an especially weak area by design. A simple example of torsion, shear and compression would be one chassis with a full tube structure and one stock. Install 300 lb springs on both which one would fail first? Obviously the stock unaltered tub will. The factory came up with a compromise by installing soft (example 90lb springs) and the stock chassis takes up the rest. By design the chassis will only put up with X amount of flex cycles and the suspension absorbs the remainder. Easier to make soft springs and flexible pivots (suspension) than creating a strong roofless chassis as the 914. Another area of focus is the rear section (behind the torque box) and also from the (cowl forward). The cowl is about 1/2 as high as the length of the center longs. This is a powerful lever created on the longs if you can see it as a hinge mechanism. The same occurs from just behind the doors from the qtr panels rearward. The factory made the longs thicker, boxed and wide to compensate for the thinner sheetmetal in the fore and aft area's of the unibody. Why? If the gauge of metal were the same across the platform the center section would be overcome by at least 12 times the energy imposed by the areas behind and in front of it. The middle would succumb to metal fatigue and fail. Taking this further on the 914 unibody. I have never seen a passenger side long crack from fatigue. I have seen numerous driver side longs cracked at the E-Brake notch in the long. The reason for this is the right side long has a long and unobstructed box. It's elastic limits are greater because it is allowed to flex more through its length of travel (span). The drivers side is limited by the E-brake notch. The energy or flex comes to a hault at the notch (underside of the inner long) and the same amount of energy on the opposite side is only allowed to to travel say 1/2 as far. Everyone knows when you put on a thick tight fitting sweatshirt your arms become harder to articulate if it fits really snug. Imagine the above paragraph with one armed cocooned in a tight sweatshirt sleeve and the other without. You will get the picture. |
jamara Harebrained idea about chassis stiffening Nov 14 2007, 03:51 PM
jd74914 Welding in those square pipes would take a lot of ... Nov 14 2007, 04:11 PM
jamara
Welding in those square pipes would take a lot of... Nov 14 2007, 06:13 PM
davep 8lb density pour foam? Are we talking polyurethane... Nov 14 2007, 06:38 PM
jamara
8lb density pour foam? Are we talking polyurethan... Nov 14 2007, 07:14 PM
kwales As an engineer and a car repairer, the foam idea m... Nov 14 2007, 07:43 PM
jd74914
As an engineer and a car repairer, the foam idea ... Nov 14 2007, 11:18 PM
Aaron Cox
As an engineer and a car repairer, the foam idea... Nov 15 2007, 10:52 AM
byndbad914
The foam does work as a stiffener. That's pro... Nov 15 2007, 11:47 AM
jd74914
The foam does work as a stiffener. That's pr... Nov 15 2007, 01:40 PM
jamara
The foam does work as a stiffener. That's pr... Nov 15 2007, 04:52 PM
drive-ability jamara,
I like the fact your thinking outside th... Nov 14 2007, 09:50 PM
byndbad914 I would hack the inside of the longs and the floor... Nov 14 2007, 10:45 PM
andys
I would hack the inside of the longs and the floo... Nov 15 2007, 11:41 AM
Borderline My idea would be to work on the outside similar to... Nov 14 2007, 11:20 PM
davep Free rise density of the foam is less than 1 lb pe... Nov 15 2007, 11:58 AM
jamara
Free rise density of the foam is less than 1 lb p... Nov 15 2007, 03:58 PM
davep You guys might be correct that some of the foams m... Nov 15 2007, 04:37 PM
kwales I've built aluminum and foam core structures f... Nov 15 2007, 07:41 PM
jamara
I've built aluminum and foam core structures ... Nov 16 2007, 04:16 PM
Jeff Hail
I've built aluminum and foam core structures... Nov 16 2007, 08:16 PM
Brando I second the carbon fiber idea.
The only way I co... Nov 15 2007, 09:02 PM
byndbad914 jamara - I am familiar with using poly in cavities... Nov 15 2007, 11:03 PM
kwales As one guy that did aircraft structures taught me,... Nov 16 2007, 07:57 PM
woobn8r If the "ENGMAN" kit is "double bagg... Nov 17 2007, 05:04 PM
JPB I like the idea of making the car stiffer but it i... Nov 18 2007, 10:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:14 PM |
