| Bill Meyer |
Nov 18 2007, 07:44 PM
Newbie ![]() Group: Members Posts: 44 Joined: 11-October 07 From: Prairie Village, KS Member No.: 8,210 |
I'm new to the 914 world and coming from the 911 side the only thing I miss is the power. Otherwise, I actually prefer the new 914 to my Bahama Yellow 67 911S.
Anyway, it's a 73 1.7 that's been recently rebuilt, the only change being a Webcam and Hydraulic lifters, no idea of specs on the cam though. What about a bigger bore kit on my 1.7. How big can you go on these cases, and will the FI and stock heads starve it for power? I'm not looking for a race motor, just something that scoots around nicely, say 100-125HP. Whatever I do I absolutely want to retain Fuel injection. That being said, is my best option a later 2.0, and if so, how much reliable HP can be done with FI? Thanks for any advice, Bill oh, and here's a pic of the new girl. Attached image(s)
| toon1 |
Nov 18 2007, 09:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Jake raby did a radio show on building a motor on a budget.
You can do a 100- 125hp for about 2k if you are savy. with you 1.7 you have 90mm bores and a 66mm stroke crank and small valve heads. A 2L is 94/71 with 3 intake stud heads, 039 castings. About the only thing usable from your motor, for the HP you want, is the case. You might be better off finding a 2L and rebuilding it. That being said, Jake likes the 1.7 cases better than the 2.0 cases and build his high HP motors with them There are plenty of options for a higher Hp motor and tons of info in the archives. For a motor with 100-125hp the stock system will be hard to retain. It can be done but there are alot of adjustments needed to the MPS. If you went with an aftermarket FI(megasquirt or SDS) system you will have FAR more tunability. ALso my .02 |
Bill Meyer Wanting a bit more power out of the 1.7.. options? Nov 18 2007, 07:44 PM
stateofidleness that is a beautiful color!
no help from here o... Nov 18 2007, 08:33 PM
tracks914 1.7's are for cruising. For power, real power ... Nov 18 2007, 08:48 PM
gregrobbins Nice car!
115-125 HP is realistic with a 2056... Nov 18 2007, 09:40 PM
McMark Yup, 2056 is your reasonable limit for stock FI. ... Nov 18 2007, 10:01 PM
Bill Meyer Thanks for the info!
Will my FI fit 2.0 heads... Nov 19 2007, 09:04 AM
Jake Raby The 96s that firt the standard 1.7 bore are very t... Nov 19 2007, 09:58 AM
toon1 You just got a reply from the master himself
Fo... Nov 19 2007, 10:12 AM
johannes The cheap way (under 2000 $) is to unbolt the... Nov 19 2007, 11:34 AM
Bill Meyer Haven't really set a budget or anything, just ... Nov 19 2007, 01:11 PM
So.Cal.914
Haven't really set a budget or anything, just... Nov 19 2007, 01:27 PM
nein14 Just Turbo Charge it :)
Nov 19 2007, 01:20 PM
johannes In the Raby Kit you have 2 new special heads, flyw... Nov 19 2007, 03:12 PM
Joe Ricard Just put a 1911cc in my car as an interim. H grind... Nov 19 2007, 03:37 PM
Jake Raby The engine kit is an unassembled engine... More th... Nov 19 2007, 03:47 PM
Joe Ricard Are my heads in the mail yet? Nov 19 2007, 03:53 PM
Jake Raby
Yep, on the way t... Nov 19 2007, 06:00 PM
orthobiz Since Jack, Joe and others are weighing in on this... Nov 19 2007, 04:04 PM
rdauenhauer Ok Ill chime in, The 1.7 in good tune is a zippy ... Nov 19 2007, 06:37 PM
brant with all of the 1911 guys on this thread
as I cont... Nov 19 2007, 09:12 PM
Brando The AA Cylinders from Jake, with Keith Black Pisto... Nov 19 2007, 09:57 PM
toon1
as I con... Nov 19 2007, 10:52 PM
brant
as I co... Nov 19 2007, 11:15 PM
orange914 you should get everyone that is building a 1911 or... Nov 19 2007, 11:44 PM
brant so I've went through about 8 2.0/4 race motors... Nov 19 2007, 11:51 PM
orange914
so I've went through about 8 2.0/4 race motor... Nov 19 2007, 11:57 PM
Joe Ricard Looking at my spread sheet I was at 2200 for my 20... Nov 20 2007, 06:05 AM
toon1
so I've went through about 8 2.0/4 race motor... Nov 20 2007, 09:27 AM
Jake Raby we will be offering our OEM bored German cylinders... Nov 20 2007, 11:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:19 PM |
