> 911 front hubs, 2 different thicknesses, Which is which???
hwgunner
post Nov 19 2007, 11:27 PM
914 Parts @ Discount Prices 800.321.5432
Here is a pic of the 2 hubs. is the thinner one from an early car. Anyone know the years for the 2 of these??
Eric_Shea
post Nov 20 2007, 10:22 AM
PMB Performance
The hub on the right is from an early non vented car 65-68. The thickness changed when they went to vented rotors to support the weight. 69-73 hubs were the same. I believe in 74 the hub stayed the same but the wheel bearings changed size because a thicker spindle on the strut.
More than likely the other way around.
The thickness didn't change because of the weight, it changed to allow the new vented rotor to move "outward" and center in the caliper groove. It got thinner. So, the caliper received 7mm spacers, they spaced the caliper nose out by 7mm. The hub would then be thinner (rotor mounts to the backside of the hub) by 3.5-4mm to split the difference in the 7mm spacer. The thinner one on the right should be the later hub.
Spindles on 911's were always the same in those years.
Part numbers should tell the complete story.
911quest
post Nov 20 2007, 02:53 PM
QUOTE(Eric_Shea @ Nov 20 2007, 08:22 AM) *
It's also so the wheel won't rub on the caliper.....
- Lo-Fi Version Time is now: 13th September 2025 - 07:38 AM
