> 944 stubs on 911 hubs, the bearing spacer info you need
Aaron Cox
post Mar 16 2007, 08:23 PM
Professional Tinkerer
ok, so there are two ways to do this im told, you can make a spacer to fill the area on the stub where the dust seal on a 944 used to live, or you can lathe that off, and let the stub sit deeper into the hub-
so here are pics with dimensions......
ill have to go back and write in the dimensions.... cant read the calipers on a few. (shoulda got the digital ones LOL)
the materials required.
Bearing, early 911 hub, 951 stub, calipers.
Bearing width.
diameter of "dust seal area" and diameter of bearing area on hub.
width of dust seal area
width of bearing area on hub
combined....
bearing diameter if you need it.
amallagh
post Nov 29 2007, 05:24 PM
John/Clay,
very informative post. Can you confirm what type of 944 axles can be used and answer a few more questions.
I think there are 3 or 4 different types based around differnet models and years. The Performance Products part number in an earlier post seems to match up with '87-'89 Turbo and '89-'91 S2.
Are these the only shafts that will work or can the shafts of the earlier 944 or 944 S be used ?
Do you also need to use the stub shaft from this same Turbo/S2 drive shaft or are the are stub shafts from the different 944 drive shafts interchangeable ?
According to the same Performance Products listing there were different 944 shafts for :-
1) '83-'85 944
2) '85-'88 944/944S/924S & '86 Turbo
3) '87-'89 Turbo & '89-'91 S2
Can anyone confirm exactly which part numbers (preferrably the Porsche part number) is required in this conversion ?
From what I have understood of the previous posts on here the other parts required are listed below -
2x '76 911 (915 transmission) 6 bolt, coarse spline drive flanges.
2x '69-'73 911 hub flanges with wheel bolts
2x '75-'84 911 stub axle 6-bolt OR 944 stub axle type TBC above (the 911 stub axle is a 'nice to have' if you don't want to machine down the hubs)
Can someone confirm the Porsche part numbers for these parts as well to make the search for parts a little similier.
Many thanks - if this set up works as described then it sounds fantastic.
Andrew
Aaron Cox   944 stubs on 911 hubs, the bearing spacer info you need   Mar 16 2007, 08:23 PM
John   I prefer the later hubs, but then you would probab...   Mar 16 2007, 09:18 PM
Luke M   Hey, Aaron Is that the setup that you have on your...   Mar 17 2007, 03:32 PM
ClayPerrine   Hey, Aaron Is that the setup that you have on you...   Mar 17 2007, 03:40 PM
Aaron Cox   Hey, Aaron Is that the setup that you have on yo...   Mar 17 2007, 08:09 PM
ClayPerrine   [quote name='ClayPerrine' post='876049' date='Mar...   Mar 18 2007, 01:19 AM
LarryR   Hey, Aaron Is that the setup that you have on you...   Mar 17 2007, 10:35 PM
Luke M   Clay, Which setup do you have on your six? I'm...   Mar 17 2007, 05:30 PM
ClayPerrine   Clay, Which setup do you have on your six? I...   Mar 18 2007, 01:21 AM
John   Those 944 axles that bolt up to the coarse spline ...   Mar 18 2007, 02:07 AM
Luke M   Clay, Could you break down the parts/years that yo...   Mar 18 2007, 08:10 AM
ClayPerrine   Clay, Could you break down the parts/years that y...   Mar 18 2007, 09:02 AM
Luke M   Thanks, for the info. Clay. Looks like that may be...   Mar 18 2007, 04:32 PM
Aaron Cox   someone find me those tranny flanges.....   Mar 18 2007, 08:42 PM
John   A no machining/no spacer solution would be: 1. 76...   Mar 18 2007, 10:00 PM
amallagh   John/Clay, very informative post. Can you confirm...   Nov 29 2007, 05:24 PM
Krieger914   The 944 axles are too long by about 3/4". Th...   Nov 29 2007, 07:08 PM
Elliot Cannon   Aaron, are we EVER going to see this car on the ro...   Nov 29 2007, 07:11 PM
shoguneagle   Excellent articles and could not be more timely. ...   Nov 29 2007, 11:00 PM
amallagh   John/Clay, very informative post. Can you confirm...   Nov 30 2007, 02:40 AM
- Lo-Fi Version Time is now: 6th November 2026 - 09:33 AM
