> 944 stubs on 911 hubs, the bearing spacer info you need
Aaron Cox
post Mar 16 2007, 08:23 PM
Professional Tinkerer
ok, so there are two ways to do this im told, you can make a spacer to fill the area on the stub where the dust seal on a 944 used to live, or you can lathe that off, and let the stub sit deeper into the hub-
so here are pics with dimensions......
ill have to go back and write in the dimensions.... cant read the calipers on a few. (shoulda got the digital ones LOL)
the materials required.
Bearing, early 911 hub, 951 stub, calipers.
Bearing width.
diameter of "dust seal area" and diameter of bearing area on hub.
width of dust seal area
width of bearing area on hub
combined....
bearing diameter if you need it.
Elliot Cannon
post Nov 29 2007, 07:11 PM
Group: Retired Members
Aaron, are we EVER going to see this car on the road again???
Aaron Cox   944 stubs on 911 hubs, the bearing spacer info you need   Mar 16 2007, 08:23 PM
John   I prefer the later hubs, but then you would probab...   Mar 16 2007, 09:18 PM
Luke M   Hey, Aaron Is that the setup that you have on your...   Mar 17 2007, 03:32 PM
ClayPerrine   Hey, Aaron Is that the setup that you have on you...   Mar 17 2007, 03:40 PM
Aaron Cox   Hey, Aaron Is that the setup that you have on yo...   Mar 17 2007, 08:09 PM
ClayPerrine   [quote name='ClayPerrine' post='876049' date='Mar...   Mar 18 2007, 01:19 AM
LarryR   Hey, Aaron Is that the setup that you have on you...   Mar 17 2007, 10:35 PM
Luke M   Clay, Which setup do you have on your six? I'm...   Mar 17 2007, 05:30 PM
ClayPerrine   Clay, Which setup do you have on your six? I...   Mar 18 2007, 01:21 AM
John   Those 944 axles that bolt up to the coarse spline ...   Mar 18 2007, 02:07 AM
Luke M   Clay, Could you break down the parts/years that yo...   Mar 18 2007, 08:10 AM
ClayPerrine   Clay, Could you break down the parts/years that y...   Mar 18 2007, 09:02 AM
Luke M   Thanks, for the info. Clay. Looks like that may be...   Mar 18 2007, 04:32 PM
Aaron Cox   someone find me those tranny flanges.....   Mar 18 2007, 08:42 PM
John   A no machining/no spacer solution would be: 1. 76...   Mar 18 2007, 10:00 PM
amallagh   John/Clay, very informative post. Can you confirm...   Nov 29 2007, 05:24 PM
Krieger914   The 944 axles are too long by about 3/4". Th...   Nov 29 2007, 07:08 PM
Elliot Cannon   Aaron, are we EVER going to see this car on the ro...   Nov 29 2007, 07:11 PM
shoguneagle   Excellent articles and could not be more timely. ...   Nov 29 2007, 11:00 PM
amallagh   John/Clay, very informative post. Can you confirm...   Nov 30 2007, 02:40 AM
- Lo-Fi Version Time is now: 6th November 2026 - 09:34 AM
