Angle Grinder, Which should a 914 owner own? |
maf914 |
Dec 16 2003, 11:58 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I just returned a Mikata 4" angle grinder to Home Depot. It was the first of these I had bought and it seemed like a decent buy at $49. What I didn't know was that most grinders have a 5/8" shank while the model I bought had a metric M10-1.25 shank. Of course no one, including HD, carries tool accessories for that shank size and I would have had to order things from Mikata. I checked with two industrial suppliers without luck. So I figured I would bail out and start over.
So my question is: What is the preferred grinder make and size for general auto and home work? 4" or 4.5"? Are all 5/8" shank grinders the same when it comes to accessories, or are some easier to equip? I want to use the usual accessories like brushes, grinding and cutting disks, etc. Any suggestions will be appreciated. Mike |
URY914 |
Dec 16 2003, 05:22 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Dave,
You're right-I do the same thing. Changing the attachment is a PITA when you only need it for a minute. I bought another grinder and put a sanding disc on it. Saves time. Paul |
Lo-Fi Version | Time is now: 1st June 2024 - 04:42 AM |
