914 Side seals on targa bar $12, Repair kit |
Mikey914 |
Nov 17 2007, 06:11 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've had allot of feedback on these, and have changed the concept slightly with these. This is more of a "repair kit". Most buyers have been taking the stock ends and gluing the old ends to the new seals. I'm also including 8 low profile screws to help with the installation. Any gaps that need to be filled can be caulked with polyurethane caulking.
And, of course you can cut and glue the ends if you want. This comes with 8 low profile screws to help the installation. You can still use these by cutting and filling if you do not have the ends. An excellent alternative to complete new seals, most of the time the ends are in the best shape. Attached image(s) |
McMark |
Dec 15 2007, 02:39 AM
I'm confused as to this seal. You say four per car. I get the one on targa bar, the vertical one. Is the other one the top seal that mounts to the targa top?
Mikey914 |
Dec 18 2007, 01:45 AM
I'm confused as to this seal. You say four per car. I get the one on targa bar, the vertical one. Is the other one the top seal that mounts to the targa top? There are actually 2 on the body and 2 on the targa top. I was looking at reproducing the side ones on the body. The other 2 on the targa top are slightly different. I'll check on these tomorrow to see if the same die would work for both, but from my recollection they were different. There may be some confusion on the window sweeps. I'm still waiting on the materials, and I have some test fitting I need to do on these. Probably 1st of the year. |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:02 AM |
