> 914 and electric speedo?, Anyone done this?
GS Guy
post Dec 18 2007, 06:25 AM
Anyone worked out a solution for running an Autometer (or similar) electronic speedometer directly from the 914 trans speedometer drive?
I know about the VDO adapter - which I gather attaches to the end of the speedometer cable for a VW and converts to electronic signal for the speedo. I presume this would also attach to the end of a 914 cable similar to the VW? Seen several other adapters/converters as well, mostly for domestic applications.
What I'd like is to do away with the speedometer cable altogether, attach the signal converter either directly to the speedo angle drive - or better yet directly to the output on the transaxle without even using the angle drive. Any ideas on how to do this? Seems like a much cleaner solution just running wires off the trans than all the adapters, drives, cables just to get to an electronic signal.
I may have to end up whipping up a custom installation for this, but no sense re-inventing the wheel if someone has already worked out a solution.
Jeff
GS Guy   914 and electric speedo?   Dec 18 2007, 06:25 AM
Vacca Rabite   I bet for similar cost, you could just put in a GP...   Dec 18 2007, 10:04 AM
alpha434   I bet for similar cost, you could just put in a G...   Jan 19 2008, 08:59 PM
Phoenix-MN   Here's how I did mine http://www.phoenixhobbi...   Dec 18 2007, 11:20 AM
effutuo101   http://www.navigadget.com/index.php/2007/0...ud-sp...   Dec 18 2007, 11:53 AM
GS Guy   Thanks for the replies guys, but gees - since when...   Dec 18 2007, 03:55 PM
racunniff   Thanks for the replies guys, but gees - since whe...   Dec 20 2007, 08:23 AM
GrayMatter   Has anyone tried adapting one of the pulse generat...   Dec 23 2007, 07:43 PM
GS Guy   If it's any help, I found a company that said ...   Dec 23 2007, 08:52 PM
GS Guy   Just a follow up here - in case anyone was holding...   Jan 19 2008, 04:20 PM
SirAndy   damm, that's nice! :trophy: Andy   Jan 19 2008, 04:46 PM
Vacca Rabite   WANT! Want. want want want want. poor. ...   Jan 19 2008, 05:20 PM
BIGKAT_83   I used this for my LS1 V8 conversion for the VSS s...   Jan 19 2008, 07:11 PM
degreeoff   I wonder if that would work with a late model 911 ...   Jan 19 2008, 07:17 PM
Vacca Rabite   What I'd like is to do away with the speedome...   Jan 19 2008, 10:52 PM
Phoenix 914-6GT   Wow Zach... what do you really think :D Leads Gu...   Jan 19 2008, 11:12 PM
Cap'n Krusty   Well there's the answer to the question nobody...   Jan 20 2008, 01:40 AM
GS Guy   No offense taken from the GPS guys - I thought tha...   Jan 20 2008, 07:21 AM
alpha434   What's the thread pattern? Pics?   Jan 20 2008, 08:21 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:09 AM
