jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
see pic
Attached image(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
The HE's bolt right up.
Gotta use the same system front to back. Same size pipe internally from 1.7 to 2.0 liter. Rich |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
The HE's bolt right up. Gotta use the same system front to back. Same size pipe internally from 1.7 to 2.0 liter. Rich Clarification. The inside diameter of the SSI 1.7/1.8 and 2.0 units are the same. But the ID of the stock steel HE's are in fact different. The stock steel 2.0 HE ID is larger than the stock steel 1.7/1.8 units. |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
The HE's bolt right up. Gotta use the same system front to back. Same size pipe internally from 1.7 to 2.0 liter. Rich Clarification. The inside diameter of the SSI 1.7/1.8 and 2.0 units are the same. But the ID of the stock steel HE's are in fact different. The stock steel 2.0 HE ID is larger than the stock steel 1.7/1.8 units. so... my 1.7 s/s h/e's ARE the same i.d. as 2.0 s/s's? but they are curved up at the end and obviously they must be curved out also. (the curves are my way of telling difference befween the 1.7 & .02). that is why the 1.7 measures 1.5" wider??? the 2.0 long block cant be 1.5" wider...??? mike |
Lo-Fi Version | Time is now: 16th June 2024 - 07:09 PM |
