> Anyone looked into using non-914 injectors?, For increased flow.
TeenerTim
post Dec 21 2007, 03:54 PM
I'm just thinking about different options for better/cheap performance that are kind of bolt-on. I saw someones flow sheet on the 914 injectors and they were about 100cc. Browsing through e-bay I found Ford 2.3L injectors that were 147cc and Ford Focus injectors that were 200cc. That seems like it might be the equivilent of swapping a 2-bbl carb with a 4-bbl carb. Of course the impedance is different but I'm sure there's a way around that.
I know Jake has said the plenum is restrictive but it also seems like you could open that up with a Dremel. Is this just naive?
I was also thinking about building a megasquirt unit that fit inside the stock 914 ECU case as a stealth upgrade.
- Lo-Fi Version Time is now: 15th July 2025 - 03:23 AM
