| TimK |
Dec 21 2007, 08:13 PM
Electric Vehicle Nut ![]() Group: Members Posts: 29 Joined: 29-September 07 From: Portland, OR Member No.: 8,170 Region Association: Pacific Northwest |
Here's a real corker of a problem that I'm completely stumped on. Any input or experiments to try would be most welcome. Just a warning: it's a rather long post...
I recently converted a 914 to an all-electric vehicle and everything works beautifully except for the whole car shakes nastily at 5400 RPM. I've been trying to figure this one out for months now. You can see the whole electric vehicle conversion process (including a transmisison rebuild) at 914ev.blogspot.com. Most of my more recent posts, especially those in September, document all the experiments I went through to isolate the issue. My last experiment went like this: I removed the friction disk out of the clutch and attached the electric motor to the transmission so that the only moving parts that touched the input shaft of the tranny was the pilot bearing in the flywheel. I put the transmission in gear so that the input shaft wouldn't turn (or at least I'd see it on the CV joint couplings). After spinning the electric motor (attached to flywheel) up to 5400RPM, the whole assembly rattled nastily and skittered across the floor like a hockey puck in slow motion. Here's the confusing part. I acquired another "broken" transmission that had no oil in it and put that on instead. Again, the input shaft won't spin and the only thing it touches is the pilot bearing in the flywheel. I can spin this assembly up to 8000 RPM and get no rattling whatsoever. The only measurable difference between the two transmissions is that the first one (that I rebuilt at home) has a runout on the input shaft of about 10 mils (10 thousandths of an inch). The "broken" transmission has only 2 mils of runout on the input shaft. The Porsche specification for the runout is 3.9 mils. This leads me to the possible conclusion that (1) the rebuilt transmission has a bent input shaft or (2) there are loose parts that hit a resonant frequency of 5400 RPM inside the rebuilt transmission. Since the non-functional "broken" transmission has no resonance, I'm planning on buying a transmission rebuilt by a real mechanic (not me) and see if that resonates. Still, until that arrives, I'm looking for other experiments I could try. Perhaps I could take the input shaft out of the "broken" transmission and put it in the home-rebuilt transmission and see if the runout goes away and the vibration with it. Any suggestions or experiments to try are welcome. Thanks! Cheers, Tim p.s. The photo below shows the 914 in the garage with the electric motor (replaced the engine) attached to the home-rebuilt tranny on the left with the "broken" tranny on the right. Attached image(s)
| Chris Pincetich |
Dec 23 2007, 12:28 AM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I'm totally psyched on your project - I want to do one some day!
My advice - since you only use 2-3 gears just change the shaft or go with the other transaxle and be done. That rebuild alignment was your original problem and this is a tough one to get right w/o expert help+tools. Get that cool car back on the road and perhaps work on the perfect rebuild WITH NEW RATIOS after you have a good feel for the way the AC drives. (IMG:style_emoticons/default/beerchug.gif) |
TimK Electric 914 has resonant frequency at 5400 RPM Dec 21 2007, 08:13 PM
Dr Evil Hey Tim,
thanks for getting back to me with those... Dec 22 2007, 01:17 AM
TimK Hi Dr. Evil,
Thanks a bunch for the input. Sin... Dec 22 2007, 12:22 PM
Demick 10mils of runout is quite a bit. I would suspect ... Dec 22 2007, 12:46 PM
TimK
As far as a replacement transmission, your 914 is... Dec 22 2007, 12:57 PM
Dr Evil The best deal by far on first gear parts is the ... Dec 22 2007, 12:50 PM
TimK
Without the seal measurements the pinion depth is... Dec 22 2007, 01:01 PM
Dr Evil If it is complete mush then I guess you cant. That... Dec 22 2007, 02:05 PM
racunniff
I'm totally psyched on your project - I want ... Dec 23 2007, 12:43 AM
Twystd1 You aren't running your tranny over the design... Dec 23 2007, 02:15 AM
JRust Hey Tim, I don't now if it would help but... I... Dec 23 2007, 03:08 AM
TimK Hi Jamie,
Thanks a bunch for the offer. I hav... Dec 23 2007, 09:39 AM
boxstr Tim, Contact me in reference to ordering trans par... Dec 23 2007, 10:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:17 PM |
