high idle |
high idle |
lonnie152 |
Dec 25 2007, 03:24 PM
Newbie Group: Members Posts: 40 Joined: 24-November 07 From: end of the oregon trail Member No.: 8,372 |
74 with FI 2.0, can not get idle down (from 1200 +) . adjustment screw turned all the way in. with a complete turn or a bit more the other way, it will go up. is this a case of worn out needle valve/carb. any help really appreciated.
also any suggestions on a local mechanic in oregon city, oregon area also appreciated. many thanks. |
toon1 |
Dec 26 2007, 12:52 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
gentelmen-want to thank you all for your suggestions and i will following up on many of them tomorrow morn. the car is new to me by a month or so, however a recent tune up has been done and it is a nice car with 87K miles. i am aware the car sat for many years and the previous owner did a lot of fix up. the motor runs strong (150 in all cylinders) , no smoke or leaks. just installed complete msd system (box, coil and wires) and while it definately runs smoother, the high idle is definately not right and so needs to be fixed. if anything else comes to mind pls let me know. Did you have to remove the dizzy for the conversion? maybe there is a vac line that didn't get reconnected. |
lonnie152 |
Dec 26 2007, 10:12 PM
spent morning installing IMI high torque starter and love the results, a big difference.
checked for vacume leaks with no luck. over next day or some will check vacume advance and will do some research on aar. going after alternator, heat exchangers and muffler tomorrow. ps. cleaned and reconnected grounding straps, battery, etc. , yes it does really help. thx to all those who have mentioned it. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:17 AM |
