> Installed Weltmeister Shift Lockout Kit, My experiences installing the kit...
olav
post Jan 6 2003, 10:07 PM
Group: Retired Members
Hi All.
I just thought I would share this experience with everyone.
I was experiencing the problem of frequently touching reverse when I shifted from either 1st to 2nd or from 3rd to 2nd. It was very annoying especially when I was doing a quick down shift and sometimes would hit reverse hard evern though I thought I was being careful.
I read on one of the forums that Weltmeister sells a kit, the Shift Lockout Kit, will help fix the problem so I decided to give it a shot.
Well, I got the kit that consists of a drill bit (specially designed to cut through the very hard metal that makes up the reverse lock-out plate), two springs, to shafts for the springs, and some instructions.
What the kit does is add two more springs to the two existing spring in the shift assembly.
At first I didn't realize that I had to drill holes in my shifter assembly but I quickly got over that and following the intructions started marking off 1/2" inside from the existing spring locations on all four locations.
I then set up my drill and proceeded to drill the holes. The first hole went well only having to penetrate the stamped metal of the shifter housing, the second hole I made it through the housing and thanks to the special drill bit supplied cut through the harded metal.
I decided to stop there and install the spring and shaft into the newly created holes. This was a problem. The instructions say "press the spring on the shaft...it's going to be hard..."
It was hard. So hard in fact it was impossible. Was I discouraged? Read on.
I had to build a special spring compressor tool to get the job done. I went to the local hardware store with my spring and sourced out a bolt that would fit down the center of the spring.
I then go a nut that would fit on the end of the bolt with a washer.
I cut off the end to the bold so all that was left was a threaded shaft.
I bought a bunch of e-clamps to fit over the bolts threads.
The spring compressor works like so:
I put the bolt through the hole I just drilled, put the nut /washer on the end outside the shifter harness/plate.
I then put the spring over the bolt then pushed an e-clamp onto the bolt through the spring at the very end. The e-clamp secures the spring to the bolt.
I then started to tighten up the nut at the other end which compressed the spring. I had to make sure that the bolt didn't rotate other wise the e-clamp would screw itself off.
After some tightening the spring compressed enought to fit into the space between the two holes. Now I took a pair of pliers and removed the e-clamp (make sure the spring lines up with the holes ).
At this point I carefully slide in the shaft that came with the kit and at-the-same-time removed the bolt . This has to be done at the same time otherwise the spring will buckle and snap out causing one to start the whole process again.
So, after that I got one spring in it started to drill the other two remaining holes to put the spring in. To my suprise the drill bit that came with the kit had broken. The special cutting edge that was bonded to the rest of the drill bit had snapped off and was useless.
I didn't think this was a big deal and went to get another drill bit, a carbon super duper cutter. Well it cut through the normal metal but not the hardened steel. I was pissed!!
I couldn't do anything at the time to get the rest of the kit installed so I put my car together with half the kit in and tried it out.
What a difference it makes!! I highly recommend this kit. Even with half the kit in I don't touch reverse at all and my shifts are way better. I was skeptical at first but the trouble is worth it.
BTW. I phone the kit supplier and they sent a replacement bit and I installed the second spring.
It's great. No more vague shifts at all.
I just thought I would share my experience and help out anyone if they were planning to do this very cool and cannot-be-without addition to the 914 shifter.
Tools neeeded: Electric drill, pliers, stuff to disassemble the shifting parts.
Regards.
Olav
mdwman
post Dec 31 2007, 10:16 AM
That sounds a much simpler. Is it necessary to actually remove the shifter to replace the lockout springs? What about the lockout plate? Is there a photo anywhere of this set up so I can see what to expect when I get in there?
Thanks for the info.
banger
post Dec 31 2007, 02:32 PM
My method for getting the springs in was pretty easy. I put the spring up against one of the holes, and inserted the shaft 2-3 coils into the spring. Then I bent the spring upward into a U shape, so the other end of the spring lined up with the hole on the other side. I then inserted the tail end of the drill bit into that hole, and up 2-3 coils of the spring. This way you have both ends of the spring help by "pins". I was then able to push down on the U part of the spring, and push the shaft in. The spring kind of pops down as the shaft goes through. Then use the shaft to push the drill bit out, and you are all set. This was the easiest way I could find to get the spring in, and keep it from flying across the room.
olav   Installed Weltmeister Shift Lockout Kit   Jan 6 2003, 10:07 PM
Curvie Roadlover   Olav, had you posted this story before on the PP ...   Jan 6 2003, 10:30 PM
olav   Yes, I posted it on Rennlist but I didn't thin...   Jan 6 2003, 10:40 PM
rick 918-S   With some photo's you could submit it as a tec...   Jan 6 2003, 11:30 PM
olav   Sure, I'll take some pictures of the spring co...   Jan 6 2003, 11:44 PM
campbellcj   I'd like to hear/see more too. I actually hav...   Jan 6 2003, 11:46 PM
boxstr   I was having some of the same problems discussed e...   Jan 7 2003, 12:00 AM
Brad Roberts   Yep. The plate wears out. Great article Olav. Let ...   Jan 7 2003, 12:02 AM
olav   No doubt refreshing the shifters parts, essentiall...   Jan 7 2003, 12:13 AM
Brad Roberts   Put it on your calender for that weekend. B   Jan 7 2003, 12:55 AM
Jeroen   Olav, Nice write up! we'll use it for the...   Jan 7 2003, 09:26 AM
olav   Thanks guys. I'll post some pictures of the s...   Jan 7 2003, 10:35 AM
Gint   Nice write up. I too would like to see pics of yo...   Jan 7 2003, 02:16 PM
olav   That's kinda personal isn't it? Well, sin...   Jan 7 2003, 03:39 PM
mdwman   Were there ever photos posted for this process? I...   Dec 31 2007, 08:47 AM
rhodyguy   to simplify things a bit, you can just swap out th...   Dec 31 2007, 08:55 AM
RickS   to simplify things a bit, you can just swap out t...   Feb 13 2016, 09:47 PM
mdwman   That sounds a much simpler. Is it necessary to ac...   Dec 31 2007, 10:16 AM
banger   My method for getting the springs in was pretty ea...   Dec 31 2007, 02:32 PM
- Lo-Fi Version Time is now: 18th August 2025 - 07:21 PM
