Project Turbo 914 begins..., (yes, I know you can't turbo a 914) |
ottox914 |
Dec 24 2006, 01:44 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Just a little teaser on this winters project. Last winter I dug into this little update:
http://www.914world.com/bbs2/index.php?sho...c=53733&hl= This winter will be phase 2. This photo will show some of the goodies under the tree, which will soon be under/on the car. The WRX intercooler has one round inlet on the back, and 2 smaller oval outlets under the opposite end tank. These will each exit and attach to some CB performance turbo "hats" for the ITB's that have 2" tubes welded to them. Some silicone elbows, and we're good. The intercooler will mount on braces running across the engine bay to support the intercooler as close to the GT lid as possible. I'll see how it goes, and probably do some yarn tuft testing to see about airflow in and around that lid, but I could always use the SDS computer to switch on either a puller or pusher fan below the intercooler based on boost, if needed. The turbo will mount on a custom flange/adaptor to be built to connect the turbo to the collector of the Kerry Hunter exhaust system. The turbo is a small Garrett VNT. The compressor map looks like a good match for this motor. I'm expecting the VNT turbo to give good low rpm thorttle response. Starting out at 5-6 psi, I'd be happy to see 10 when I'm done, but will tune to run safely on 93 pump gas and see where we end up. Off the back of the transmission, where the factory exhaust hanger mounted, I'll mount a similar hanger to support the turbo and exhaust system. A Tildon differential pump will return the oil to a willing valve cover. Oil will be taken from a "T" at the pressure sending unit on the case. There is a blow off valve to be added to the intercooler, and a mocal thermostat/sandwitch plate adaptor for the oil cooler, which has a thermostat controlled fan. I'll be adding an ignition switched relay for power to the fan and scavenge pump, so both will have power when the key is on. The pump will run continously, the fan when the thermo switch tells it to. Add some pressure side stainless or aluminum tubing from the turbo, thru the back engine tin, into the round inlet on the intercooler and we're done. Except for another trip to the LSE dyno, for some additional tuning. I'll keep posting as progress would warrent. Attached image(s) |
ottox914 |
Jan 6 2008, 08:21 PM
More pics- here are some of the oiling system, there have been plenty of questions about that. I have been consulting with Corky Bell of the Bell engineering group, Inc. He seemed to think the oil pressure of the system was not a problem with this "old school" turbo, but that if I were going with a newer style ball bearing turbo we might need to be a little more careful. Good enough for Corky, good enough for me.
The current configuration, which will be changing, uses a catch can supplied by one of our members who has built a monster turbo'd orange 6cyl. Wonder who that is... The catch can hangs to low. In reality, its no lower than the engine bar, but is hangs below the valance, and the oil return line is low also. Not that I go 4 wheeling with this car, but if I went off at an auto cross, or plugged a cone just the wrong way, I could rip it appart. Mr. Bell to the rescue again. He seemed to think the catch can would not be needed on a smaller turbo at lower rpms (its not like the stock motor will spin to 7k rpms or anything) such as this one, and advised me that going direct from the turbo oil outlet to the scavenge pump should work fine. So I will be revising the oiling system to do just that, with a very short drain off the turbo, a 90 degree turn right under the turbo, and then attach a line straight to the scavenge pump. On to the pics- First is the back of the car, and what you can see, and not see relative to the turbo system. My hopes are to tuck it all up under the car, so all you see is a slightly larger exhaust pipe. Next is a close up of the back of the car. The current oiling return system is a little low. Pic of the catch can, which will be going away. Here is the catch can and pump. Close up of the drain from the turbo. I'll unclamp the catch can, remove the hose, and braze on a 90 degree fitting to get the oil line tucked up under the car a little better. Better for looks as well as safety- keeping it all attached should I go farming with the car at an auto cross. Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:19 PM |
