Project Turbo 914 begins..., (yes, I know you can't turbo a 914) |
ottox914 |
Dec 24 2006, 01:44 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Just a little teaser on this winters project. Last winter I dug into this little update:
http://www.914world.com/bbs2/index.php?sho...c=53733&hl= This winter will be phase 2. This photo will show some of the goodies under the tree, which will soon be under/on the car. The WRX intercooler has one round inlet on the back, and 2 smaller oval outlets under the opposite end tank. These will each exit and attach to some CB performance turbo "hats" for the ITB's that have 2" tubes welded to them. Some silicone elbows, and we're good. The intercooler will mount on braces running across the engine bay to support the intercooler as close to the GT lid as possible. I'll see how it goes, and probably do some yarn tuft testing to see about airflow in and around that lid, but I could always use the SDS computer to switch on either a puller or pusher fan below the intercooler based on boost, if needed. The turbo will mount on a custom flange/adaptor to be built to connect the turbo to the collector of the Kerry Hunter exhaust system. The turbo is a small Garrett VNT. The compressor map looks like a good match for this motor. I'm expecting the VNT turbo to give good low rpm thorttle response. Starting out at 5-6 psi, I'd be happy to see 10 when I'm done, but will tune to run safely on 93 pump gas and see where we end up. Off the back of the transmission, where the factory exhaust hanger mounted, I'll mount a similar hanger to support the turbo and exhaust system. A Tildon differential pump will return the oil to a willing valve cover. Oil will be taken from a "T" at the pressure sending unit on the case. There is a blow off valve to be added to the intercooler, and a mocal thermostat/sandwitch plate adaptor for the oil cooler, which has a thermostat controlled fan. I'll be adding an ignition switched relay for power to the fan and scavenge pump, so both will have power when the key is on. The pump will run continously, the fan when the thermo switch tells it to. Add some pressure side stainless or aluminum tubing from the turbo, thru the back engine tin, into the round inlet on the intercooler and we're done. Except for another trip to the LSE dyno, for some additional tuning. I'll keep posting as progress would warrent. Attached image(s) |
Sleepin |
Jan 6 2008, 10:48 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Dave, All looks good. I would say your oil return setup is your weak point if you have one. My oil return on my Civic was the area I had problems with. When I originally tapped the line I wasn't thinking and ended up tapping in to the pan beneath the oil level and it ended up scaring me into a new pan that I tapped above the oil level. I see you have had a little help from the boys at H-T.com....I have been a member there for years and I can attest....there is a lot of knowledge to be had there. If you get frustrated with your oil setup, I would suggest getting ahold of the guys at Squires Turbo Systems. They have a lot of experience dealing with low mounted turbo's and are hella nice guys to deal with! They are probably going to hook me up with a turbo for my Sequoia in the future! (....errr hopefully!!!! (IMG:style_emoticons/default/biggrin.gif) ) I think from the looks of things, once you get it going, you can ditch the catch can and rubber line with hose clamps and go with some SS braided lines and AN fittings. Then you should be able to flog the crap out of it without worrying about them lines. High pressure or low pressure, most rubber return lines end up leaking and cracking.
As far as the tubes go, that is personal preference...although they would look cool body color! I have never really agreed with coating the intercooler with anything...so I hope you leave that bare! I really hope for the best with this setup! Turbocharged engines are near and dear to my heart.....if they were closer to my wallet, I would be happier... Crazy cool!!!!! |
Lo-Fi Version | Time is now: 10th June 2024 - 07:36 PM |
