> rear number (licence) plate lights, hardware
thesey914
post Jan 16 2008, 01:55 PM
Hello, can anyone tell me the type of screw required to mount the (early) lights? Self tapper or is it a bolt?
thanks in advance
Larry.Hubby
post Jan 17 2008, 01:30 AM
Member who doesn't post much, but has a long time in 914s
They're 3.5x16mm sheet metal screws. Screws of the same description are used to hold down the aluminum strips that secure the carpet on the sills (the heads on these may be a slightly different shape, but the diameter and pitch are the same), and shorter ones (9.5mm) are used to hold on the padding on the A-pillar and above the windshield. 3.5mm metric sheet metal screws are almost the same size as the US #6 screws, and I've found that #6x3/4" screws you can get at any hardware store work just as well as the correct metric parts.
Larry
So.Cal.914
post Jan 17 2008, 01:44 AM
"...And it has a front trunk too."
QUOTE(Larry Hubby @ Jan 16 2008, 11:30 PM) *
Larry
Larry, aren't those more of a flat head (slightly rounded counter sunk) and the one's for the LPL are panheads...Right?
- Lo-Fi Version Time is now: 6th July 2025 - 11:49 AM
