looking for information on d-jet 2056 conversion, calling all M.P.S. guys * need info.** |
orange914 |
Jan 17 2008, 08:31 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i am setting up my d-jet to operate the new 2056, it origanally was 1.7. i need some experianced input on running either a "modified perameter" 1.7 or 2.0 m.p.s. which of these 2 combo.s would work the best?:
1) a modified 1.7 (max. re-calibrated setting for 2.0) with increased fuel press. (note) higher fuel pressure increases atomazation so this combo may have benifit over #2? PROS: i could re-calibrate/use my good 1.7 M.P.S., CONS: have to adjust a/f with increased fuel press. at regulator and set on a/f scope 2) a modified 2.0 (able to set to 2056 fuel requirements) PROS:? keep stock fuel pressure CONS: have to locate/buy or trade a good 2.0 m.p.s. for re-calibrate answers to the below questions will be helpful in desiding how to go i'm trying to understand if the m.p.s. operation, does it have a profound (dont know if thats exactly the word i'm looking for) effect on the e.c.m.'s output for the full range of f.i. operation? would programing a 1.7 to 2.0 a/f settings + raised fuel injection press. do the same (or better?) than a reprogrammed 2.0 m.p.s. set to 2056 a/f calibration? when you re-program the m.p.s. what data exactly does it input to the computor? manifold pressure and?? is it very basic data or does it relay more complex values and ranges? if i go route #2 DOES ANYONE HAVE A 2.0 M.P.S. 4 SALE OR PARTS SWAP? thanks, mike EDIT NOTE: new info. from p.m. so it's basic duty is the same as a modern map sensor. if i adjusted fuel pressure higher it could find the balance a/f ratio by 1) increased pulse width (max. setting,) plus- 2) incress fuel pressure to fine tune a/f ratio across the board since m.p.s. is handling the three parameters. |
JeffBowlsby |
Jan 17 2008, 09:18 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You should probably review Brad Anders webpage Mike...
http://members.rennlist.com/pbanders/manif...sure_sensor.htm |
Lo-Fi Version | Time is now: 8th June 2024 - 03:42 AM |
