i am setting up my d-jet to operate the new 2056, it origanally was 1.7. i need some experianced input on running either a "modified perameter" 1.7 or 2.0 m.p.s. which of these 2 combo.s would work the best?:
1) a modified 1.7 (max. re-calibrated setting for 2.0) with increased fuel press.
(note) higher fuel pressure increases atomazation so this combo may have benifit over #2?
PROS: i could re-calibrate/use my good 1.7 M.P.S.,
CONS: have to adjust a/f with increased fuel press. at regulator and set on a/f scope
2) a modified 2.0 (able to set to 2056 fuel requirements)
PROS:? keep stock fuel pressure
CONS: have to locate/buy or trade a good 2.0 m.p.s. for re-calibrate
answers to the below questions will be helpful in desiding how to go
i'm trying to understand if the m.p.s. operation, does it have a profound (dont know if thats exactly the word i'm looking for) effect on the e.c.m.'s output for the full range of f.i. operation?
would programing a 1.7 to 2.0 a/f settings + raised fuel injection press. do the same (or better?) than a reprogrammed 2.0 m.p.s. set to 2056 a/f calibration? when you re-program the m.p.s. what data exactly does it input to the computor? manifold pressure and?? is it very basic data or does it relay more complex values and ranges?
if i go route #2 DOES ANYONE HAVE A 2.0 M.P.S. 4 SALE OR PARTS SWAP?
thanks, mike
EDIT NOTE:
new info. from p.m.
so it's basic duty is the same as a modern map sensor. if i adjusted fuel pressure higher it could find the balance a/f ratio by 1) increased pulse width (max. setting,) plus- 2) incress fuel pressure to fine tune a/f ratio across the board since m.p.s. is handling the three parameters.
