| jaybird840 |
Jan 17 2008, 09:11 AM
Member ![]() ![]() Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Hi All,
I'm starting to source the parts for putting a 2.7 into my teener. I'd like to hear the pros and cons of both the bulkhead and the quick six mount. Thanks! --jaybird |
| Root_Werks |
Jan 18 2008, 09:09 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,930 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I have run the following mounts on converted 914-6's:
Quick six bars ranging from home built units GPR use to sell back in the early 90's to PM tube bar that flexes like crazy to even a 2 piece bar design that was cool. Used and installed the RJ mount, Vellos bulkhead and Maddog bulkhead. Probably 6-7 different mounts and I have learned that any "Quick Six" bar is great to get you going, but nothing to run forever. Best bulkhead mount I have ever used is the one Maddog makes that is a copy of the RJ and Vellos mounts. I only prefer the Maddog over the RJ mount because the Maddog requires that you pull the wirring loom all the way out from the back up to the firewall, mount/weld mount and push it back through the maddog mount. The RJ mount goes OVER the wirring loom. Soooooo, if you weld on your RJ mount and have to pull through wires, you're pretty much screwed. The maddog takes more time to install, but easier to work on the car later if needed. Sort of past my 2 cents I guess, call it a dime. (IMG:style_emoticons/default/biggrin.gif) |
jaybird840 bulkhead vs. quick six mount for conversion Jan 17 2008, 09:11 AM
dflesburg We (flesburgs) are all using bulkhead mounts. I am... Jan 17 2008, 09:50 AM
degreeoff Well I have the same setup in the works as my frie... Jan 17 2008, 09:52 AM
sww914 Quick six mounts require no welding and they make ... Jan 17 2008, 09:59 AM
Dave_Darling Quick Six mounts are easy to install, that's a... Jan 17 2008, 10:04 AM
Quick Six mounts are easy to install, that's ... Jan 17 2008, 02:09 PM
djm914-6 I had a quick six in my car when I bought it. It k... Jan 17 2008, 10:35 AM
Phoenix 914-6GT I still have the bar in mine and I hate it. When y... Jan 17 2008, 12:01 PM
9146986 The quick bars cause more problems than they solve... Jan 18 2008, 08:45 AM
The RJ mount goes OVER the wirring loom. Soooooo... Jan 19 2008, 12:34 PM
9146986 You can still pull the wiring harness through Rich... Jan 19 2008, 08:58 AM
John I prefer bulkhead mounts. I prefer to fabricate m... Jan 19 2008, 12:43 PM
carr914 The Quick six bars are junk.
The Patrick Chromoly... Jan 19 2008, 01:43 PM
BKLA
The Patrick Chromol... Jan 19 2008, 03:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:40 PM |
