| GS Guy |
Dec 18 2007, 06:25 AM
Member ![]() ![]() Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
Anyone worked out a solution for running an Autometer (or similar) electronic speedometer directly from the 914 trans speedometer drive?
I know about the VDO adapter - which I gather attaches to the end of the speedometer cable for a VW and converts to electronic signal for the speedo. I presume this would also attach to the end of a 914 cable similar to the VW? Seen several other adapters/converters as well, mostly for domestic applications. What I'd like is to do away with the speedometer cable altogether, attach the signal converter either directly to the speedo angle drive - or better yet directly to the output on the transaxle without even using the angle drive. Any ideas on how to do this? Seems like a much cleaner solution just running wires off the trans than all the adapters, drives, cables just to get to an electronic signal. I may have to end up whipping up a custom installation for this, but no sense re-inventing the wheel if someone has already worked out a solution. Jeff |
| VaccaRabite |
Dec 18 2007, 10:04 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I bet for similar cost, you could just put in a GPS based speedo and be done with it. No fabbing, always accurate no matter what tire size (unless you do all your driving in a tunnel).
Zach |
| alpha434 |
Jan 19 2008, 08:59 PM
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
I bet for similar cost, you could just put in a GPS based speedo and be done with it. No fabbing, always accurate no matter what tire size (unless you do all your driving in a tunnel). Zach I'm putting together a MS kit, and I was considering *just using a gps based speedo for the soft traction control system. Then I realized that if I ever go out of range, I'll be putting that fucher into limp home mode real quick. (IMG:style_emoticons/default/chair.gif) There's often a good reason for somebody wants to do something specific, and asks about it. It may be no more than personal preference- but around here, it's never because of a lack of information. Am I the only one who is offended when the very first reply is "do something else" ? |
GS Guy 914 and electric speedo? Dec 18 2007, 06:25 AM
Phoenix-MN Here's how I did mine
http://www.phoenixhobbi... Dec 18 2007, 11:20 AM
effutuo101 http://www.navigadget.com/index.php/2007/0...ud-sp... Dec 18 2007, 11:53 AM
GS Guy Thanks for the replies guys, but gees - since when... Dec 18 2007, 03:55 PM
racunniff
Thanks for the replies guys, but gees - since whe... Dec 20 2007, 08:23 AM
GrayMatter Has anyone tried adapting one of the pulse generat... Dec 23 2007, 07:43 PM
GS Guy If it's any help, I found a company that said ... Dec 23 2007, 08:52 PM
GS Guy Just a follow up here - in case anyone was holding... Jan 19 2008, 04:20 PM
SirAndy damm, that's nice!
:trophy: Andy Jan 19 2008, 04:46 PM
Vacca Rabite WANT!
Want.
want want want want.
poor. ... Jan 19 2008, 05:20 PM
BIGKAT_83 I used this for my LS1 V8 conversion for the VSS s... Jan 19 2008, 07:11 PM
degreeoff I wonder if that would work with a late model 911 ... Jan 19 2008, 07:17 PM
Vacca Rabite
What I'd like is to do away with the speedome... Jan 19 2008, 10:52 PM
Phoenix 914-6GT Wow Zach... what do you really think :D
Leads Gu... Jan 19 2008, 11:12 PM
Cap'n Krusty Well there's the answer to the question nobody... Jan 20 2008, 01:40 AM
GS Guy No offense taken from the GPS guys - I thought tha... Jan 20 2008, 07:21 AM
alpha434 What's the thread pattern?
Pics? Jan 20 2008, 08:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:43 AM |
