| GS Guy |
Dec 18 2007, 06:25 AM
Member ![]() ![]() Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
Anyone worked out a solution for running an Autometer (or similar) electronic speedometer directly from the 914 trans speedometer drive?
I know about the VDO adapter - which I gather attaches to the end of the speedometer cable for a VW and converts to electronic signal for the speedo. I presume this would also attach to the end of a 914 cable similar to the VW? Seen several other adapters/converters as well, mostly for domestic applications. What I'd like is to do away with the speedometer cable altogether, attach the signal converter either directly to the speedo angle drive - or better yet directly to the output on the transaxle without even using the angle drive. Any ideas on how to do this? Seems like a much cleaner solution just running wires off the trans than all the adapters, drives, cables just to get to an electronic signal. I may have to end up whipping up a custom installation for this, but no sense re-inventing the wheel if someone has already worked out a solution. Jeff |
| Cap'n Krusty |
Jan 20 2008, 01:40 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Well there's the answer to the question nobody's asking ........... Why? The angle drive is the weak link, and it's the one part you're using? What's wrong with the stock head unit and thwe cable. there's a LOT of nearly 40 year old teeners running around with the original cable and speedo head. The weak part of the head is the odo, and they go south in the electric speedos as ofetn as they do in the mechanical ones, and it's at least twice as expensive to repair. The Cap'n
GS Guy 914 and electric speedo? Dec 18 2007, 06:25 AM
Vacca Rabite I bet for similar cost, you could just put in a GP... Dec 18 2007, 10:04 AM
alpha434
I bet for similar cost, you could just put in a G... Jan 19 2008, 08:59 PM
Phoenix-MN Here's how I did mine
http://www.phoenixhobbi... Dec 18 2007, 11:20 AM
effutuo101 http://www.navigadget.com/index.php/2007/0...ud-sp... Dec 18 2007, 11:53 AM
GS Guy Thanks for the replies guys, but gees - since when... Dec 18 2007, 03:55 PM
racunniff
Thanks for the replies guys, but gees - since whe... Dec 20 2007, 08:23 AM
GrayMatter Has anyone tried adapting one of the pulse generat... Dec 23 2007, 07:43 PM
GS Guy If it's any help, I found a company that said ... Dec 23 2007, 08:52 PM
GS Guy Just a follow up here - in case anyone was holding... Jan 19 2008, 04:20 PM
SirAndy damm, that's nice!
:trophy: Andy Jan 19 2008, 04:46 PM
Vacca Rabite WANT!
Want.
want want want want.
poor. ... Jan 19 2008, 05:20 PM
BIGKAT_83 I used this for my LS1 V8 conversion for the VSS s... Jan 19 2008, 07:11 PM
degreeoff I wonder if that would work with a late model 911 ... Jan 19 2008, 07:17 PM
Vacca Rabite
What I'd like is to do away with the speedome... Jan 19 2008, 10:52 PM
Phoenix 914-6GT Wow Zach... what do you really think :D
Leads Gu... Jan 19 2008, 11:12 PM
GS Guy No offense taken from the GPS guys - I thought tha... Jan 20 2008, 07:21 AM
alpha434 What's the thread pattern?
Pics? Jan 20 2008, 08:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:42 AM |
