> 914/4 Headers
WizPorsche914
post Jan 31 2008, 08:51 PM
Does anyone make a header for a 914 4 cylinder ? Im finding them for the 6 but not the 4. Im trying to eliminate heat in the car.
SGB
post Jan 31 2008, 10:10 PM
just visiting
Stainless HEs ain't cheap either. The existing pipes would have to be awfully rusted to make it leak into the cabin air side. Maybe an exaust place can use a CO meter to test for leaks. The whole heat system just SMELLS, you know. Oil dripping from wherever seems to find its way into the heat exhanger part, that gets all heated up and cooked with whatever else might be in there. Have you tried just cleaning the ducting to the heater flapper valve bodies from the exchanger? All you need to get 'em out is eye gogles and a stubby flat head screwdriver.
WizPorsche914   914/4 Headers   Jan 31 2008, 08:51 PM
SGB   Tangerine Racing should be able to fix you up...   Jan 31 2008, 09:09 PM
Rand   Several companies make them. What's your budg...   Jan 31 2008, 09:13 PM
WizPorsche914   Headers will 100% eliminate cabin heat right ?   Jan 31 2008, 09:16 PM
SGB   The Tangerine system will. Triad is a one man sho...   Jan 31 2008, 09:29 PM
Rand   ...Triad is a one man show like Tangerine, but I ...   Jan 31 2008, 11:44 PM
WizPorsche914   Ouch these prices are way out of my budget. I will...   Jan 31 2008, 09:44 PM
jd74914   Yep. Get some stainless heat exchangers and forget...   Jan 31 2008, 09:55 PM
SGB   Stainless HEs ain't cheap either. The existin...   Jan 31 2008, 10:10 PM
WizPorsche914   I havent tried cleaning anything yet. I just read ...   Jan 31 2008, 10:13 PM
banger   If you dont want heat, why not just cap the tubes ...   Jan 31 2008, 11:29 PM
mudfoot76   Maybe an exaust place can use a CO meter to test ...   Feb 1 2008, 07:35 AM
jd74914   Wiz, The inner HE tubes are a low grade of stainle...   Jan 31 2008, 11:36 PM
Vacca Rabite   There are also Kerry Hunter headers, and the Euro ...   Feb 1 2008, 07:07 AM
stateofidleness   is it $695 for the triad 914/4 header?? same ...   Feb 1 2008, 07:37 AM
Phoenix 914-6GT   is it $695 for the triad 914/4 header?? same...   Feb 1 2008, 11:49 AM
dr914@autoatlanta.com   Kerry is out of the header business. MSDS took hi...   Feb 1 2008, 08:39 AM
Maltese Falcon   [quote name='dr914@autoatlanta.com' post='992849' ...   Feb 19 2008, 08:57 PM
ericread   When I picked up my 914 about a year ago, the PO h...   Feb 1 2008, 08:49 AM
Vacca Rabite   Should I have a welding shop tack the exchanger ...   Feb 1 2008, 10:29 AM
TeenerTim   Does anyone make a header for a 914 4 cylinder ? ...   Feb 1 2008, 09:06 AM
jimkelly   to eliminate heat in the car - simply remove the b...   Feb 19 2008, 09:41 PM
- Lo-Fi Version Time is now: 12th September 2026 - 06:53 AM
