> More shift adjustment questions, I'm having sensory overload
mdwman
post Feb 2 2008, 11:22 PM
I've read posts on the topic, the PP tech article, and the Haynes procedure but I'm not sure I'm clear on adjusting my '73 side shift linkage.
To rotate the shift rod left or right it has to be out (disengaged) of the coupler at the shift lever, is that correct? Also, in the access hole between the seats please help me identify whats what. The shift rod is the thick bar against the drivers side. Then there are 2 thin metal tubes in the middle going through the fire wall, what are these. There is also a curved metal tube with nuts on it's middle section. Is this tube part of the shift linkage and are the nuts turned for adjustment?
I am able to access all gears but have a grind downshifting 3 to 2. I presume I am "nicking" reverse? The lockout plate looks good and the springs are Weltmeister replacements (they did not appear to be any more stout than the originals). What is the best adjustment procedure to remedy this?
Thanks for any help.
Mark
mdwman
post Feb 3 2008, 07:17 AM
How is the tranny shifted from under the car?
race914
post Feb 3 2008, 09:33 AM
QUOTE(mdwman @ Feb 3 2008, 05:17 AM) *
Take off the plastic over on the shift console and you'll see the shift rod head (page 89 in your Haynes Manual)
Here's the shift pattern (think of it as your shifter pattern 'on its side')
Hope this helps!
Gint
post Feb 3 2008, 09:55 AM
Mike Ginter
QUOTE(race914 @ Feb 3 2008, 08:33 AM) *
Hope this helps!
Where in the world did you get those graphics Greg?!?! They're fantastic!
- Lo-Fi Version Time is now: 29th July 2026 - 07:47 AM
