rufio0205 |
Member ![]() ![]() Group: Members Posts: 134 Joined: 9-September 07 From: Orlando, FL Member No.: 8,099 Region Association: South East States ![]() |
so the floors came out of my '73 2.0 today. i took out the pedal cluster, the gauges in the center console, and the master cylinder came out as well.... now the question is...would it be better to get a 914/6 master cylinder, rebuild mine, or do a big brake up grade - to the 911 calipers and what not.
what did you guys do to make the cockpit a little nicer? any suggestions? what would you change about the cockpit? |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Those are not 911 struts.
Those are 914 struts that have been drilled and 5-lug studs installed. If you look closely, those are solid rotors/hubs. 911's used an aluminum hub and had the rotor bolted to it. Those are 914 calipers and will fit, but you will be gaining nothing. Good luck with your floors. I hope you find something to weld to. |
Lo-Fi Version | Time is now: 9th July 2025 - 01:02 PM |
