rufio0205 |
Member ![]() ![]() Group: Members Posts: 134 Joined: 9-September 07 From: Orlando, FL Member No.: 8,099 Region Association: South East States ![]() |
so the floors came out of my '73 2.0 today. i took out the pedal cluster, the gauges in the center console, and the master cylinder came out as well.... now the question is...would it be better to get a 914/6 master cylinder, rebuild mine, or do a big brake up grade - to the 911 calipers and what not.
what did you guys do to make the cockpit a little nicer? any suggestions? what would you change about the cockpit? |
rufio0205 |
hey thanks for all your help guys. one more question
if i didnt replace the calipers and just did the 19mm master cylinder, what kind of improvement will i be looking at. is it worth the money? or should i just rebuild mine or get a new one or whatever |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
hey thanks for all your help guys. one more question if i didnt replace the calipers and just did the 19mm master cylinder, what kind of improvement will i be looking at. is it worth the money? or should i just rebuild mine or get a new one or whatever The 19mm master cylinder will displace more brake fluid given the same pedal travel. The pedal will be slightly harder to press, but will have less travel than the 17mm unit. Is there a problem with your 17mm unit? Is it leaking? If the master cylinder is not leaking, I would not bother with it. It will be more important to make sure your calipers (all 4 of them) are in good working order and that all pistons extend and retract as they should. Also read about setting the venting clearances on the rear calipers. If anything in the brake system needs to be rebuilt, I'd bet that the calipers will need rebuild kits. In my opinion, master cylinders are not worth rebuilding. These are just my opinions, and your milage might vary. |
Lo-Fi Version | Time is now: 9th July 2025 - 12:25 PM |
