| 914pipe |
Feb 14 2008, 09:24 PM
Say......TEEEEEEEN!!!!! ![]() ![]() Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Hi there:
There was a guy running hard pipes of 3/4" ID.... I use to have a link but doesn't work. Does anyone knows if that configuration ever worked...? Would like to hear from that guy.... I have the opportunity to get 3/4 in ID SS braided hoses.... Thanks..!!! Pics...? |
| wbergtho |
Feb 14 2008, 09:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
I have heard of people using 3/4 id hoses...and I've heard of people using copper (don't like) but it seems a wee bit small. I use 1" and 1 1/4" Gates Green stripe hoses through the heater ducts in the longitudinals. No hoses hanging under the car waiting to be wiped out on a speed bump. It takes a bit of effort to snake the lines through and to fabricate cut outs through the forward longs and forward firewalls...but if done correctly, you'll have a clean install and two continuous hoses from the engine to the radiator. More importantly, you can route the hoses in such a way that there are absolutely no sharp 90 degree bends to disrupt flow. Call Rod Simpson. He believes in the small diameter method.
Bill |
nukepipe For the V8 guys... cooling lines. Feb 14 2008, 09:24 PM
Andyrew I believe that was Rick w/ the Alien..
I would g... Feb 14 2008, 10:06 PM
nukepipe Thanks Bill.... any pics from your set up...??
... Feb 14 2008, 10:07 PM
marks914 Desert hybrids uses 3/4 black (1 in od) pipe under... Feb 15 2008, 08:52 PM
ajracer nukepipe:
Not sure which hard line installation y... Feb 15 2008, 10:10 PM
ajracer Another shot Feb 15 2008, 10:14 PM
vespasoul
Desert hybrids uses 3/4 black (1 in od) pipe unde... Feb 25 2008, 12:19 AM
nukepipe Thank you very much guys.... this really help... Feb 15 2008, 11:39 PM
jd74914 Water is water . . . Feb 25 2008, 12:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 06:22 PM |
